Old 09-26-2010, 06:18 PM   #1
docrock
docrock's Avatar
transfer case trouble
I have a 72 Chevy Truck with the running gear out of a 81 suburban. Recently I was driving and the rear wheels locked up. I put the truck in neutral and got it towed to my garage. my mechanic took the case out took it to his shop, and he said it was not rebuildable. I found a low mile case and installed it and the truck does not drive. I switched gears in the transfer case and still nothing. I have a terrible noise from the trans putting it in park. I pulled the transfer case started the engine put it in gear and the tail shaft spins. I did not grab a hold of the shaft to see how much torque it was putting out or if it was just spinning. With the transfer case on the ground I put it in gear and it seems to operate properly. while it was in 4 high I reinstalled the case and the same thing is happening. It wont drive and it wont go into Park without making noise like Im trying to be rolling and put it in park. Please help
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344
1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494
R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438
1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250
docrock is offline   Reply With Quote
Old 09-26-2010, 06:22 PM   #2
70BLAZERX2
Re: transfer case trouble
did it lockup because you were in 4wd?
70BLAZERX2 is offline   Reply With Quote
Old 09-26-2010, 06:26 PM   #3
swampfox
swampfox's Avatar
It might be the splined collar between the trans and transfer case partly stripped out .
69 gmc 4x4 lwb 327 4sd not running
swampfox is offline   Reply With Quote
Old 09-26-2010, 07:10 PM   #4
docrock
docrock's Avatar
the spline looks fine. I will check tomorrow if it is the same number of splines. It was not in 4wd. The transfer is out of an 83 truck, np208. it bolts to a 700r4. Kind of a bummer is the new transfer is a fulltime 4wd unit.
Old 09-27-2010, 01:47 AM   #5
84socal
sounds like the tcase input is different from ur output shaft that could be the culprit
84socal is offline   Reply With Quote
Old 09-27-2010, 08:28 PM   #6
docrock
docrock's Avatar
ok the trans output shaft has 27 splines. the input shaft of the transfer case has 33 spline. is there an adapter or what transfer case should I be looking for.
Old 09-28-2010, 12:13 PM   #7
docrock
docrock's Avatar
I figured it out. this transfer case would have been behind a turbo 400. So im on the hunt for a 27 spline.
Old 09-28-2010, 01:38 PM   #8
raycow
Can you swap the input shaft from your old T/C?
Ray
raycow is offline   Reply With Quote
Old 09-28-2010, 02:44 PM   #9
SWB4x4
SWB4x4's Avatar
you can change the shaft on yours as well.... if they make a 27 spline one for it. I'm assuming you have the adaptor that connects your t/c to your trans allready?? seems like the easiest thing to do if they do make the 27 spline shaft for your t/c..... check advance adaptors.
J.T.
1972 SWB 4X4 on 35"s with 6" lift all around 3/4 ton running gear with high steer and 4.88s 350/th350. SOON TO BE DONE:2" higher in front 37"s,LSX Swap,Hugger Orange & White Paint Scheme,Air Conditioning,Power Windows & Locks,Complete Gauge Kit,Tank Relocation,Double Din Nav with full Audio System.
My Build Thread http://67-72chevytrucks.com/vboard/s...=1#post4169140
SWB4x4 is offline   Reply With Quote
