What paint do you use?
Hello, I took out my factory pillar molding that are tan and I want to paint them black like the rest of my interior is going to be......so my question is there a special type of spray paint used for vehicle interiors and can it be used on metal like the front of my ash tray and glove box (and the rest of the metal dash parts)....it would also be helpful if you have pictures of what you have done with it (if you can)
Thanks!
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
![]() Join Date: Dec 2008
Re: What paint do you use?
First thing I'd do is clean it very good, then spray adhesive polymer. Duplicolor has some. And I've used appliance epoxy, this stuff gets really hard. The only problem with it is it just comes in three colors. black is one tho But it's pretty good, has a great gloss to it. But the reason for the polymer is in case you have any plastic pieces that need to be painted as well, and just for all around better adhesion. Sorry I have no pics at the moment.
Addicted to Rust
![]() Join Date: Dec 2009
I like SEM color coat on interior parts. Jay
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
Chris
clean it or wipe it off with grease and wax remover, wipe on with one rag wipe off with another clean rag.
Then if it's hard plastic I use krylon fusion spray paint, it's made for plastic and doesn't require an adhesion promoter, but might not hurt, I just don't use it, never had any problems. If it's more of a soft plastic and very flexible or if it's vinyl or fabric I use duplicolor or sem vinyl/fabric dye works great, same way wipe it down with the grease and wax remover and spray it. I could never get that stuff to work or stay stuck to hard plastic like seat belt buckles, it would always flake off on me, duplicolor or sem, sem was the worst for it. Maybe the promoter would have helped on them. I used sem on a dash cover, molded platic on dad's 84, still looks perfect, no flakes cracks chips scratches anything and it's been in and out of the truck a couple times. I just wiped it down as mentioned and no promoter and worked great.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
I don't think he was necessarily speaking of plastic. I think his parts were metal, if I read his post right. I just mentioned plastic in case there was some. I always use adhesive polymers when changing colors... it acts as an a primer. as well grease and wax remover is a good idea. But I have achieved the same results using Dawn dishwashing liquid followed by rubbing alcohol. Also when I've used the Krylon Fusion for plastics, it didn't matter how I prepped, there was trouble with it sticking properly unless I used an adhesive polymer.
duplicolor or sem vinyl/fabric dye note it's for vinyl/fabric not plastic lol Last edited by nbpro; 09-26-2010 at 10:57 PM. |
Chris
really? I never had a problem with the krylon sticking without promoter or anything. I painted my fourwheeler twice with it, once red, then switched to yellow, painted alot of the interior of the monte carlo I had with it, all the hard plastic stuff, and did alot in my truck and dad's truck with it. yea but sem says it's good for plastics too and that's all that anyone on the net recomends for interiors but it doesn't work for me on hard plastic stuff lol.
#7 | |
Well the metal stuff can be painted with anything you want to, as long as you prep it right. The plastics need to be something formulated for platics, unless you use an adhesive polymer. And as I've stated before, I always use it. It helps everything adhere or stick, and acts as a primer. I even have it on the outside of my truck where we had blocksanded the primer and the edges were sanded back to metal. I sprayed that on and it hasn't rusted.hood fender edges the bezel in the picture was painted with Duplicolor metalcast paint two years ago. Been sitting in the truck the whole time. Hasn't faded, chipped, cracked, peeled, etc. And it was coated with adhesive polymer before we painted it. So it doesn't have to be for plastics if you use the adhesive polymer.
#9 | |
Sorry, I was editing last post a bit.lol We're planning on going two tone. The top being a brandywine kandy, with black pearl sprayed over that. The bottom will be flat black.
Is the bradywine candy the reddish color in your interior? I can't get over how good your instrument bezel looks!
#12 | |
#13 | |
