Old 09-26-2010, 10:04 PM   #1
lotus
Can someone help identify the 12 bolt in my 63?
Here is a picture of the 12 bolt that is in my 63. It appears something was cut off the left side and by the center section top right something was cut off. Does this appear to be a 70's truck rear? it is a 6 lug.
lotus is offline   Reply With Quote
Old 09-26-2010, 11:13 PM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: Can someone help identify the 12 bolt in my 63?
To me, the rear looks like it's from a newer year of truck, maybe 1967 thru 1970. The mounting area was for the original panhard bar (upper right). It appears as though an aftermarket panhard has been installed bolted to the original pivot location and attached to the passenger side trailing arm.
IMO, this is an improvement as the rear axle will not move as far left/right as the axle travels up and down. Hope this helps somewhat.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 09-26-2010, 11:49 PM   #3
Captainfab
60-66 Nut
I agree with protrash64. That is definitely not a '63 12 bolt. That appears to be a '65-'70 12 bolt. I'm not sure what may have been cut off of the left side, but the upper right center is where the '65-'72 panhard bars were attached. The panhard bar that you have now is better.
Old 09-27-2010, 08:07 PM   #4
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
63 12 bolt would have a splined backing plate to mount the brakes too.
Old 09-27-2010, 11:29 PM   #5
lotus
i scrubbed on it and i can't find any stamped numbers. I lifted the rear off the ground and it acts like a open diff but i hear that is misleading with clutch packs.
Guess I just need to lite them up and see what spins
Old 10-10-2010, 10:07 PM   #6
lotus
I ordered what i thought were the right 5 lug axles for this rear. I pressed in the new studs before confirming the axles were the same. I removed the old axle and sure enough the old ones are slightly shorter than the new ones 1/4 inch give or take a little from eye balling.
What are my options? get a wider drum so the pads/braking surface line up 100%?
Shim the backing plate out?
I also have a ten bolt from a early 90s disc brake camaro. I wonder if that setup is slightly wider and would make up the difference?
or...is the only option push out the studs and try to return the axles which they may or may not take back since i pressed studs in.
thanks....
Old 10-10-2010, 11:40 PM   #7
bubba327
HOW long until spring??
bubba327's Avatar
Any idea what the panhard bar is from? Does it appear to be commercially made or a one off fabrication?
I kinda like the style-It certainly has less side to side movement
The 60-69 years were 6 lug and narrower by 1 1/2" than the later 70 and later 5 lug
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 10-11-2010, 12:49 AM   #8
Captainfab
60-66 Nut
It sounds like you may have one of the late 1970 rear ends, They were still 6 lug but were 1 1/2" wider like the '71-'87 rear ends. Just to be sure, measure your rear end WMS to WMS (wheel mounting surface) with the original axles installed. If it is the '63-early '70 width, it will measure 62". If it is the late '70-'87 width it wil;l be 63.5"
Old 10-11-2010, 01:10 AM   #9
lotus
my six lug axles are shorter than the summit 5 lug axles that I bought.
The summit ones i bought are for 70-81 and are 31.312 inches in length.
sounds like the axles are for late 70 and my 12 bolt is early 70. Is it possible to get late 70 axles to work with early 70 rear?
Old 10-11-2010, 03:29 AM   #10
raycow
It's possible, but risky. Lay one old and one new shaft side by side with the inner ends lined up. Now look at the bearing wear mark on the old shaft. Will it fall completely onto the machined area of the new shaft? If not, don't use the shafts. If it does, make spacers to move the backing plates out to meet the drums.
Ray
raycow is offline   Reply With Quote
Old 10-11-2010, 12:32 PM   #11
bubba327
bubba327's Avatar
You can always have your favorite machine shop re-drill the old axles for 5 lug. I think they have to weld one hole up if I recall.
Old 10-11-2010, 03:33 PM   #12
Captainfab
60-66 Nut
I wouldn't try and 'make them work'
I would suggest contacting Summit and see if they will exchange them for you. If not you should be able to sell them to someone in need of a set of new axles. You could try listing them in the classifieds on the forum here if you were a supporting member.
Old 10-11-2010, 11:00 PM   #13
protrash64
protrash64's Avatar
bubba...CPP sells that panhard set-up. Maybe some other places, too.
Old 10-12-2010, 08:05 PM   #14
mrlush
I have a 12 bolt in my 63.
It seems that the drums are pressed on as there is no backing plate attaching the drums.
Question... since this 12 bolt does not have backing plates, is it going to be impossible to upgrade to disc brakes?
mrlush is offline   Reply With Quote
Old 10-12-2010, 08:21 PM   #15
raycow
You got me scratching my head here. The 63 12 bolt definitely has backing plates. Those are what the wheel cylinders, shoes, parking brake lever, etc are attached to. The drums are held in place by the wheel studs and have nothing to do with the backing plates. Could you please post a pic showing what you are talking about?
Ray
Old 10-12-2010, 08:44 PM   #16
mrlush
Ray
I mis-spoke. It's not the drums I'm referring to, but the backing plate is usually attached by 4 bolts to a flange. That flange is used for calipers in disc upgrade kits. It looks like my backing plate is pressed on instead on bolted on. Any ideas?
Old 10-12-2010, 09:02 PM   #17
raycow
Wow! I see it, but I still don't believe it. There has to be some kind of reasonable explanation for that, but I sure haven't got a clue what it is.
Ray
Old 10-12-2010, 09:44 PM   #18
protrash64
protrash64's Avatar
I believe the early year rears 60?-63 were not bolted on. Dont know how they come apart. Pull the axles??
Old 10-12-2010, 09:56 PM   #19
mrlush
Yeah, I've been baffled.
I just found my service manual. It looks like the have to be cut off to be replaced.
I guess I'll have to find a newer rearend to replace it with - the way I drive, drums are not an option... besides, I'll need to rebuild it, I can get a different housing for cheap.
Just thought I'd ask, Thanks guys!
Old 10-13-2010, 12:24 AM   #20
Captainfab
60-66 Nut
Yes that is how the '63 12 bolts were....pressed on backing plates. You could use that housing and convert to discs, but you would have to weld the caliper brackets onto the axle tubes.
Old 10-13-2010, 06:57 AM   #21
aerotruk63
aerotruk63's Avatar
There's been a guy on ebay trying to sell NOS splined backing plates for the 63 differential. He has a kit which included the master cylinder.
