Old 09-26-2010, 10:24 PM   #1
geoff.clark
SheetMetalNoob
geoff.clark's Avatar
Going Crazy - Trailer Bearings
I know this has nothing to do with my truck, but this weekend I spent more time at Northern Tool than I did working on what should have been a easy afternoon. Well this started off with a free trailer from my uncle. It has been sitting in his yard for 5 years.
So it started with getting wheels and tires replaced. Found out one of the wheels was rusted thru. After replacing this, I figured I should go ahead and replace the bearings, seal & race ways. Now this is where my problems started - I dont own a caliper, so going on what I could figure out based on old parts. This is what I found to work for my hub.
Outer CUP / Raceway - 1 1/16
Outer Bearing - 1 1/16
Inner CUP - 1 1/4
Inner Bearing - 1 3/8
Seal - 1 1/2
The inner is what really kicked my butt with multiple trips. I finally figured the Hub would support 1 1/4 cup and 1 1/4 bearing and 1 1/2 seal. By determing the cup size, Norther Tool labels their packaging to help you put everthing else together. But after getting back home for the 3rd time today. I noticed the 1 1/4 bearing will not fit over the spindle and it appears to need a 1 3/8 bearing.
The 1 3/8 bearing appears to fit into the 1 1/4 cup - dont see to many issues their or at least not yet. Is this common? Do I just have the incorrect spindle for the Hub? Can you see any issues using a 1 3/8 bearing in a 1 1/4 cup?
Thanks for any help...
Geoff Clark
Classic Truck NoOb
83 Chevy Custom Deluxe I6 250 lwb (aka) Trash Runner
geoff.clark is offline   Reply With Quote
Old 09-26-2010, 10:28 PM   #2
texastrendz
Re: Going Crazy - Trailer Bearings
i just did the same thing not too long ago. i went the easy route, i bought a complete axle kit for 159.99. this included everything hub to hub. i figured since all of the other stuff was bad, why not.
texastrendz is offline   Reply With Quote
Old 09-26-2010, 10:56 PM   #3
fixit-p
fixit-p's Avatar
Were there no numbers on the bearings???
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 09-26-2010, 11:32 PM   #4
geoff.clark
SheetMetalNoob
Not that I could find. Cleaned them up - but couldn't see anything about size.
Geoff Clark
Classic Truck NoOb
Old 09-27-2010, 09:39 AM   #5
Shane
Shane's Avatar
most Chinese built bearings don't have numbers on them ... take your dimensions to a local industrial supply house and have them matched up with quality U.S. built bearings.
Shane is offline   Reply With Quote
