Got some ?????s
ok so im going to get new weather stripping for my door windows my ? is how do i replace it. Do i take the window out or what? and if i have to take the window out how do i do that. 2nd im getting a safety switch replaced as well is there anything speical i have to do to make it work i heard it had to b in the right place or it wont work. 3rd how wide of rims can i run on the front of my truck. also my truck is a 71 c10 2wd sorry i should have put that first thanks for your help.
71 c10 with a 305. new dd wohoo 1956 chevy bel air hard top with a 327. 1998 honda passport V6 old dd. |
Re: Got some ?????s
Anyone?????
Re: Got some ?????s
I'm interested in this as well, someone will answer sooner or later.
----------------------------------------- My 67 c10 Thread. http://67-72chevytrucks.com/vboard/s...d.php?t=409192 |
Re: Got some ?????s
Yes a lot of us would like to hear from someone that know a bit about changing the window seals on the doors. anyone be our hero!
Re: Got some ?????s
Easy to replace without taking the window out. (1) remove door panel. (2) remove bolt holding the track. (3) remove old track material starting at the top. (4) with the bolt out you can side it past the glass and down into the lower track. Window should be down from the top about 5 or 6 inches. Be careful not to bang around too much while the track is unbolted as it will not hold the window very well. Good Liuck!
I am a Referee of life.
Re: Got some ?????s
The FAQ's section will have some really good write-ups(some with pictures) on all of the weatherstripping.There's no way I could repeat all of whats been put there.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Re: Got some ?????s
Whats the key search word for this in FAQ's? my searches come up empty most every time.. Thanks!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
