Old 09-27-2010, 01:25 AM   #1
dutsuno
exhaust question??
im planning on getting the lmc dual exhaust. muffs. rear exit.
my truck is factory single exhaust. side exit. lwb 72 c10.
Will i have any fitting issues since it is not factory dual?
also, i have the ram horns that angle back. not straight down!!
dutsuno is offline   Reply With Quote
Old 09-27-2010, 10:29 AM   #2
Gobbles
Gobbles's Avatar
Re: exhaust question??
I am assuming that is the same as my truck, 70 lwb c10. I am running duals with no problems, they fit nicely just inside the frame. The only thing I had to do was find new places to suspend the pipes, super simpo. Also, how do you like your horns? I was considering putting some in instead of my stock manifold.
Trevor
"You already said spite"
Gobbles is offline   Reply With Quote
Old 09-27-2010, 12:59 PM   #3
mrein3
mrein3's Avatar
A couple of things:
Rams horns are orginal to this vintage of truck.
The stock 2wd trucks had rams horns that angled back. 4x4s had straight down, center dump rams horns when they left the factory.
I purchased the LMC kit for my 4x4. Stock was single exhaust. The 'kit' had everything I needed except hangers for the side that didn't originally have the exhaust pipe hanging from the frame. You can scour the parts list for those factory hangers from an original big block truck or simply go to NAPA like I did and purchase a generic hanger or two for the other side.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 09-27-2010, 03:55 PM   #4
dutsuno
i like the ramhorns n yes they r stock. ive been contemplating a pair of headers, but dont kno if they r necessary. it not going to b a hauling truck. and i wud have to chop the exhaust im gunna get. im tryin to keep evrything as stock as possible.
thanks 4 the info and input
i also have a build thread tht i startd recently. so wen i get the exhaust in ill post sum flix in it
http://67-72chevytrucks.com/vboard/s...d.php?t=421592
Old 09-27-2010, 06:13 PM   #5
1968CHEVYC10
1968CHEVYC10's Avatar
I just got the same kit for my truck, everything fit good except the last pipes, I ended up taking it to a muffler shop and they got them in fine, didn't need to be bent just position right and welded, if you can weld it should be fine. Oh and they charged $40 at the muffler shop.
'68 C10 LWB 6.2NA/NP833 3.73's
1968CHEVYC10 is offline   Reply With Quote
Old 10-06-2010, 10:40 PM   #6
makamer
makamer's Avatar
Do you know if the LMC kit will fit a factory big block in a 1972? It says small block but I wanted to see if anyone had done it to see if it works.
makamer is offline   Reply With Quote
Old 10-06-2010, 11:10 PM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Found this on eBay. It's the driver's side manifold for a '67-72. It's just on here for you to see what is correct.
Member Nr. 2770
exhaust, issue, lmc
