Old 09-27-2010, 08:02 AM   #1
Savage69K5
69 Blazer- No Start
Guys,
Fighting a no start condition on my 69 K5. It is a 350. Original problem was not being able to start the truck. Everything on this truck is ancient, so I haven't had a problem replacing the battery, alternator, and starter in an attempt to fix it. (Distributor is only a few months old)
Replacing the battery and alternator still did not get it to start (both were bad anyway). I wouldn't even hear the starter solenoid click. After changing the starter, I did get the K5 to start immediately, and multiple times (last night). However, this morning, I tried to start it again, and it turned over. However, trying again, all I get now is the solenoid clicking. It almost feels like it isn't getting juice. Is this now a wiring problem since I have eliminated several of the other variables? Battery cable maybe?
Savage69K5 is offline   Reply With Quote
Old 09-27-2010, 08:43 AM   #2
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: 69 Blazer- No Start
Check your cables and grounds.
Tom Vogel is offline   Reply With Quote
Old 09-27-2010, 10:38 AM   #3
RickBost
RickBost's Avatar
I agree check you stater and battery cables. If they are corded enough they will cause extra resistance and you will not get enough juice to the stater. After that i would look for a battery drain on the system if that doesn't fix the problem if you check the battery and it isn't staying charged
72 GMC Jimmy 8" lift 38" super swampers
77 GMC C15 High Seirra Short Step lowered 6/8
http://67-72chevytrucks.com/vboard/s...53#post8999053
1972 Plymouth Roadrunner
2005 Cadillac Escalade
2014 Ram Ecodiesel
RickBost is offline   Reply With Quote
Old 09-28-2010, 03:14 AM   #4
Cartoonface
Cartoonface's Avatar
Sounds like the first day it ran on the battery. That means either the alt is not charging, the voltage regulator is not closing the field circuit or the voltage(charge) can't get to the battery....because of the regulator, corroded cables or bad contact at the battery terminal. You need a simple multimeter to check the alternator output at the Alt and the Batt.
(you'll need to get it started to check it this way)
Cartoonface is offline   Reply With Quote
Old 09-28-2010, 09:33 AM   #5
Surfdriver
I had a simular problem with mine when I got it. Turned out to be a draw from the voltage regulator. I changed it out and have not had a problem since. I used a multimeter to find the draw.
Surfdriver is offline   Reply With Quote
Old 09-29-2010, 08:47 AM   #6
Savage69K5
Update- Replacing the battery cables seems to be working so far. It starts up fine now. Cross your fingers everybody
