Old 09-27-2010, 12:10 PM   #1
68Stepbed
68Stepbed's Avatar
17x9.5" rear wheels?
Who's running 17x9.5" wheels on the rear of their truck? What backspacing do you have? Pictures would be great also.
I got (2) 17x8 wheels for the front with 4" bs. I need to find (2) 17x9.5" for the rear now. I need to know what backspacing works best though.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 09-27-2010, 04:30 PM   #2
SactoJim
SactoJim's Avatar
Re: 17x9.5" rear wheels?
I'm running 4.5" BS on mine.....72 rear end. Older rear ends are narrower.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 09-27-2010, 07:01 PM   #3
brn agn
brn agn's Avatar
Mine are supposed to be 17x9.5. I measured tonight and I believe I have 5" of back spacing. Here are pictures of the clearance and a few pictures of the truck. I would have preferred to have .5"-1" less back spacing in order to move the wheel/tire towards the outside of the truck. Keep in mind, each vehicle is a little different, so your best bet is to measure, measure and measure on your truck or borrow some wheels with the backspacing you are looking for. Anyway, on to the pics...my truck is dropped 6" in the rear and has 275/50/17 tires. It also has a 5 lug rear from a 71-72 truck. I hope this helps.
Clearance on the outside of the tire:
Clearance on the inside of the tire:
Rear Shot:
3/4 Shot:
One more:
1969 C10 SWB Project Charity Case AKA "Roscoe"
1971 Cheyenne Super A Combined Effort
The Service Station-A practical ministry for those in need
brn agn is offline   Reply With Quote
Old 09-27-2010, 07:18 PM   #4
ATrain707
Is that a 2in drop in the front and a 3in in the rear?
ATrain707 is offline   Reply With Quote
Old 09-27-2010, 07:25 PM   #5
brn agn
brn agn's Avatar
Mine is 3.5" in the front and 6" in the rear.
Old 09-27-2010, 07:42 PM   #6
ATrain707
Posted via Mobile DeviceOh ok I wanna lower mine 3 in the front and 4 in the rear but I'm not sure if my 20x8.5 would fit cuz I'm gonna have to use 1in spacer to get them to fit I think
Old 09-28-2010, 10:18 AM   #7
68Stepbed
68Stepbed's Avatar
brn agn, Are you sure that's 5" of bs? That looks more like 5.5" from what I've been looking at. I agree it needs less bs to sit further toward the edge of the fender.
Also, for what it's worth, I'm going with Torque Thrust II's as well.
Here's a shot of see ten's truck with 4.75" bs. I like the way it looks.
Matt
Old 09-28-2010, 01:27 PM   #8
HuggerCST
HuggerCST's Avatar
Mine are 9.5s with a 4" drop, and have 5 & 1/2" backspace, (almost rubbing inside) but I agree that 4.75" would be just about right.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 09-28-2010, 02:15 PM   #9
OldSkool71
C/10 CLUB MEMBER
OldSkool71's Avatar
Here are mine 17x9.5...not sure of backspacing though...they were on it when I bought it...they look good....only rub on the inside when I get the rearend tilted on a pretty good angle...I'll try and measure and get back to you....
-Ron-
OldSkool71 is offline   Reply With Quote
Old 09-28-2010, 02:37 PM   #10
dmwphoto
dmwphoto's Avatar
I has 17 x 8 with 4" BS on front and 17 x 9.5 with 5.56 BS on back. It looks to me like my plans for lowering 3.5 front/ 4 rear may be tricky. will let you all see and know how that goes.
dmwphoto is offline   Reply With Quote
Old 09-28-2010, 02:58 PM   #11
68Stepbed
68Stepbed's Avatar
OK, so I now know I need to get at least a 5" bs if not 4.75"
Thanks for all the photos and info, guys.
Some tire sizes would be nice as well. I'd like to have a tad more beef than the 275/50/17. I'm thinking a 275/55/17-255/55/17 combo would look great.
Matt
Old 09-28-2010, 04:07 PM   #12
brn agn
brn agn's Avatar
It is very possible that it is 5.5". I bought the wheels used and was measuring as best as I could with the tires mounted and wheels bolted on the truck.
Old 09-28-2010, 08:21 PM   #13
slowtruck
The TT2's only come in a 5.5 BS on the 9.5x17 wheel with 5 on 5 bolt pattern.
I have the same wheels on my 67' with a step bed with a 71/72 rear and it is very close, but clears fine.
slowtruck is offline   Reply With Quote
Old 09-29-2010, 08:19 AM   #14
68Stepbed
68Stepbed's Avatar
Yes, standard bs was 5.5". AR doesn't even make the 17x9.5 for stock anymore, they're all custom order only now. Jeg's is the only place I've seen that still has any in stock, and they have the 5.5" bs. They're also only 269.99, which is a good price. I may pay the higher price and get custom bs though.
slowtruck, got any pics?
Matt
