Old 02-26-2003, 06:18 PM   #1
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
Cutting Coils???
How much can I get away with cutting my coils to lower my truck? I want a 2-3" drop in the front where my coils are so how much should I cut off to acheve this? Also anyone know of a place in MA where I can get my rear leaf springs de-arched? Thanks
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 02-26-2003, 06:46 PM   #2
crazy longhorn
Fabricate till you "puke"
Hotrod, I have done it, but will say its not the best way. If you are going to cut the coils, take 1 full ring(they will seat properly top & bottom), & you will see a 2 1/2-3" drop. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-26-2003, 07:00 PM   #3
cdowns
cdowns's Avatar
BAD DECISION
Old 02-26-2003, 08:32 PM   #4
Gene
Gene's Avatar
Bad decision? I disagree. I cut mine, took a full coil off and lowered it 2 1/2 inches up front. I have lowered all years of Chevy trucks, from an 83 with drop spindles to a 90 with 3 inch drop tubular A-arms to many 67-72 chevy trucks. Yes cutting a coil affects the front end geometry but not enough to cause problems IMO. Mine rides great, was aligned by a professional and the tires wear evenly.
I say yes there are better ways to achieve a front drop than cutting a coil, but if your funds are limited I say go for the cut. I would go 1/2 a coil at a time in case your drop is too extreme for you.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 02-26-2003, 08:34 PM   #5
70c10
67-72 Addict!
70c10's Avatar
My buddy cut his neighbors 71' one full coil with no probs over 2 years ago. I'll still go with drop coils though.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 02-26-2003, 09:22 PM   #6
Bowtie468
Bowtie468's Avatar
Yeah, drop spindles would be the best route, but sometimes you do what you have to do. I wouldn't cut more than 1 coil though !
Chris
click here to see my buildpage
http://67-72chevytrucks.com/vboard/s...d.php?t=394656
1979 C10 Silverado Big10 SWB
Factory 454/400
Cardinal Red/Santa Fe Tan (original paint)
1969 Camaro X44 LS swap
1968 C10 SWB Fleetside (SOLD)
468BBC MultiPort TPI / Dynamic EFI P4
Black/Black
1963 Nova SS convertible (SOLD)
194 I6/ PowerGlide
Bowtie468 is offline   Reply With Quote
Old 02-26-2003, 09:30 PM   #7
crazy longhorn
Yea, I cut mine about 12 yrs ago.......back then nobody offered a drop spring for the 67-72. It was a temporary deal(posta been anyway), but I have logged about 12,000 miles on the cut coils & no problems with ride or handling..........crazyL
