Old 02-26-2003, 06:43 PM   #1
Lil Greg
Lightbulb Fuel sending units
First off hello to everyone ! , and now to the good part questions questions . Ok here we go i'm building a truck from scratch i have a 87 shortbed frame and duel 16 gallon tanks ,75 cab and front sheetmetal , 81 fleetside bed and my my 68 396ci /th400 im yankin out of my 56 gmc and am having problems finding and deciding which sending units to use should i buy ones for a 87 to match the tanks ($400 a piece at dealership) or try to get some for a 75 to match the gauge cluster? and would it hurt to put the 75 units in the 87 tanks?......Whoe ok i'm and my hands are cramping lol......too much typing..............anyone can u please help!
Lil Greg is offline   Reply With Quote
Old 02-26-2003, 06:51 PM   #2
Low87
been here longer than Liz
Low87's Avatar
You can get 0-90 ohm GM sending units at Summit for $75.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 02-26-2003, 06:51 PM   #3
Low87
Low87's Avatar
And by the way, you will now answer to "Mini Me"
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 02-26-2003, 06:58 PM   #4
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
LMAO!! you have an admirerer!!!
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 02-27-2003, 12:42 PM   #5
PHOENIX
Hey greg are they just like stock, except cheaper and not GM, or are they a different setup all together?
p/n please
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 02-27-2003, 01:31 PM   #6
Low87
Low87's Avatar
SUMMIT
SUM-290180 GM: 0 to 90 OHM, 8 1/2 in long, fuel sending unit Fuel Sender, 0-90 Ohm, 8 1/2" Long $72.39
SUM-290181 GM: 0 to 90 ohm, 11 in. long, sending unit Fuel Sender, 0-90 Ohm, 11" Long $72.95
VDO
VDO-226002D 10 to 180 ohms, adjustable from 6 in. to 23 in., fuel tank sending unit ... $27.95
(not sure about this one, but will obviously work with VDO gauges.)
VDO-360900D Universal, 1/8 in.-27 NPT, 80 psi (5 bar), steel, cadmium plated, pressure sending unit ... $21.95
(another cheap one from VDO)
Auto Meter
ATM-3262 240 to 33 ohms, fuel level sending unit Fuel level Sender, Universal, For 240/33 Ohms Gauge Models $31.95
Racer's Choice, Inc.
RCI-7060A 0-90 ohms, RCI tube type sending unit for fuel cells with foam ... $54.95
I assume the Summit ones are more expensive because they are GM replacement units? The fuel cell I'm getting that Jeff has (SUM-290108) has the SUM-290180 sending unit in it.
It only took me about 2 hours to get these part numbers since the Summit site is so freaking fast.
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 02-27-2003, 01:54 PM   #7
PHOENIX
I never took a sending unit our of a truck like ours. Does is have a float that you can bend to adjust the reading level. These look different (then I expected), will they work? Will there be any problems? I really need to get my gauge working. Im hoping to take off the bed soon, replace the tank (maybe), I might go with a new stainless tank, then install all new hoses and stuff right there at the tank. Im also going to cut the switch valve out of the loop. I dont really use the 2-tank system very much and its going to cost me more then its worth (to me) to get it fixed.
Anyone ever used the summit units shown above?
Which one would I need for my 16 gallon tank (the 8-1/2" or 11")?
Thanks Greg for your time finding the info
Old 02-27-2003, 02:01 PM   #8
Low87
Low87's Avatar
I'll leave the technical answers up to the other guys, Brandon really helped me in that area so maybe he'll catch this. I've never pulled a sending unit so I assumed they all look like the Summit pictures.
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 02-27-2003, 02:14 PM   #9
Lil Greg
The vdo-22602d is just a straight up sending unit with no fuel hose hook ups i think if its the same i have in my 56's aluminum tank and the summit tube types i think are the same so u have to plumb your tank elsewhere for fuel i,m just looking for a stock replacement if possible.
Old 02-27-2003, 02:23 PM   #10
Low87
Low87's Avatar
Here you go Mini-Me;
www.chevyduty.com
(1973-75) Gas Tank Sending Unit-Pickup Part # 23-541 $69.95
(1980-87) Gas Tank Sending Unit-Pickup Part # 23-545 $69.95
Take your pick! Looks better than $300 from the dealership like you said.
Hey Eddie, there's even comparison pictures there! (they are different)
I just did a parts search of "sending unit", it comes up with 3 pages of results.
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 02-27-2003, 02:36 PM   #11
Lil Greg
Ok thank Low87...........Mini you signing out..........lmao
Old 02-27-2003, 02:38 PM   #12
Low87
Low87's Avatar
Oops, forgot to plug a board member, see what you can find at www.gmcpauls.com too.
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
