Old 09-27-2010, 08:10 PM   #1
67chevy1series
67chevy1series's Avatar
under coating on bed only for cst ????
i got a 67 bed ( fleet ) and it has under coating on the bottom not the outside but on the back after the lower body line do all 67 beds have under coating or just the cst the reason i ask is longhorn.. s thread said all cst had additional under coating and that helps seperates custom and cst yes the bed has holes for tim so i know it was a least a little special
67chevy1series is offline   Reply With Quote
Old 09-27-2010, 10:18 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: under coating on bed only for cst ????
At the risk of someone else knowing for sure, my bet is that undercoating was not offered on a given trim line, but as an aftermarket item. I don't recall my '69 Truck Dealer's sales book saying anything about a CST having undercoating as a feature of that trim level.
Member Nr. 2770
Old 09-27-2010, 10:44 PM   #3
70cst
70cst's Avatar
I would have to agree with ChevLoRay. I picked up a 71 take off bed and it had no coating but just bare metal.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 09-27-2010, 10:56 PM   #4
Dark Knight
Dark Knight's Avatar
In the 60's and 70's there was this stuff called Ziebart. It was named after its inventor (a German guy). There were little shops set up everywhere that would spray it on. It was usually sprayed in the cavities between the bed walls, under the cab, inside the doors, and the wheelwells. That's probably why my truck didn't have a bunch of rust on it. lol
Here's a little info:
http://www.entrepreneur.com/franchis.../282971-0.html
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS
-1983 Chevy Silverado C1500- 383 stroker, TH400
-1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears
-And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket
"The only thing we have to fear is fear itself." -FDR (and maybe rust too)
You've gotta be able to stop and steer before you can go fast!
Dark Knight is offline   Reply With Quote
Old 09-27-2010, 10:57 PM   #5
67chevy1series
hmm my cab has factory or dealer under coating i remeber longhorn mans i think i forgot his username but he has a list of the option each chevy 10 level was packed with and for cst it said full wheel caps bright metal trim buckets (for 67) undercoating
Old 09-27-2010, 10:59 PM   #6
70cst
70cst's Avatar
I know my 1970 CST had no factory undercoating. But it is possible the earlier trucks got factory undercoating.
Old 09-27-2010, 11:08 PM   #7
67chevy1series
well my truck has undercoating in the doors becauce my dad i have under coated inner fender wells and my cab had under coating in some spots and my new bed only has it under the last bodyline not in between the bed walls
Old 09-28-2010, 07:26 AM   #8
rsavage
rsavage's Avatar
Undercoating was (and still is in the Northeast) usually offered as a dealer option as a way to get some more $ in the sale. If it is the tar type it will be hard now and brittle and was probably done at the dealer. Ziebart was and is good stuff and was usually done at a specialty shop. Ziebart is still around. They drill holes in the door edges, jambs etc. and use wands to spray it into inaccessible areas.The holes were plugged with little plastic plugs so it is easy to spot a ziebarted vehicle. It is more amber/yellowish color than black if I recall correctly. Undercoating can be both good and bad. If the seal is breached it will trap moisture underneath and rot things out faster. Probably no way of telling who did yours.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
