Resident Lurker
Steering Column: D shaft to splined shaft coupler?
I installed a new ididit "knockoff" steering column that I picked up at a swap meet for a song. The column has a D shaft, while the steering box shaft requires a splined shaft. Does anyone make an adapter or a shaft that will accept the D shaft from the column and bolt to the original steering box?
Also, does anyone know what the part # for the flat column plug to curved under dash harness plug adapter is? Thanks and thanks!
The Rotten Mule: '72 Chevy Short Step Project- http://67-72chevytrucks.com/vboard/s...d.php?t=417252 "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats."- H.L. Mencken |
Junior Member
Re: Steering Column: D shaft to splined shaft coupler?
Ididit has them. I don't have the part #'s. They have a web site. I got mine from RB's Obsolete in Arizona.
63 C10 70 Coronet R/T 67 C10 70 Dart Swinger 71 K10 |
Resident Lurker
Thank you.
I bought an 81 for suspension and brake parts. It had a lower steering shaft that had a D type at the coupling and a regular rag joint at the other end. Probably true of all 73-87 models. Check your local junkyard. The length of these can be changed by sliding them together.
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
