what air bags are you running?
deciding what air bags to run in the front a rear of my 71.. what are u guys running size wise and single or dual port?
Re: what air bags are you running?
air lift dominators for me. 2600 single port.
![]() Join Date: Apr 2004
slam specialties re7s
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
![]() Join Date: Sep 2007
air lift dominators for me also. 2600 single port. So far so good
Tim |
vw guy & now c-10 guy
![]() Join Date: Sep 2008
expanding on the OP's question... could somebody please explain what dual port bags are for? i never understood why you would need dual port bags. thanks
I can only think of a few of reasons to have dual port bags:
1) someone building a ride that they can "hop". You could run twice as much air to the bags as a single port bag. see this video: 2) seperate lines for lift and dump valves? 3) or one for airline for lift/dump, other port for pressure gauge sensor. it may help simplify the plumbing. I personally dont understand the needs, but then again my needs are simple: lift the truck to drive, and drop it when parked. |
Kill Bill...et
I guess if you're wanting a "hopper" dual ports would be good. More air volume pumped into the bag. Not really my bag and I've seen these trucks bounce 3 inches off the ground with single port bags with 1/2 inch lines.
how much lift are you guys getting with re7's??
im kinda worried about not getting enough lift if i door my truck and run a 22 |
#13 |
Resistance is Futile
re7's front, re8's rear
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#14 |
dual ports are often used in industrial applications (where our bags originated) to provide separate intake and exhaust access.
