![]() Join Date: Jan 2010
WTB sway bar chassis brackets
I went to the local U-Pull It and took a sway bar off a 71 C20.
Will those frame brackets mount on to my C10? Who sells these? |
"THE GREEN GOBLIN"
Re: WTB sway bar chassis brackets
Are you talking about these?and these.. earlyclassic sells them I have seen them for stock hight trucks and some for lowerd trucks
http://www.earlyclassic.com/catalog....hock+absorbers
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
"THE GREEN GOBLIN"
Also (CPP) classicperform has them for stock hight and lowerd trucks as well..
http://www.classicperform.com/6092chevtrk.htm#11
The originals from the donor will work. But you'll probably like the brackets for lowered trucks better
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration. |
Junior Member
![]() Join Date: Mar 2007
cant you just bolt the bushings on without the brackets?
frontstreetcycle on Instagram |
![]() Join Date: Jul 2006
Yes, on lowered trucks no problem. You can also use the stock height brackets and put the sway bar "inside" of it, gaining clearance.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
I couldnt bolt mine to the frame cause it hit the front cross support. I could trim it down some to clear, but I decided to make some spacers out of some -1" aluminum I hade laying around....
