Old 09-28-2010, 11:04 AM   #1
1942
63, 4 speed ..
Is the 4 speed gear box from a 63 model with a 230c engine, a 3 speed + overdrive? or just a normal 4speed? ( granny gear 1st )
And will a V8 fitt directly on the trans?
1942 is offline   Reply With Quote
Old 09-28-2010, 05:30 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: 63, 4 speed ..
You probably have an SM420 old school 4 speed truck transmission. It's a conventional four speed (not overdrive) as high gear is 1:1. Here's a link showing more information than you'll probably ever want to know:
http://www.novak-adapt.com/knowledge/sm420.htm
The transmission bolt pattern matches the standard Chevy V8 bellhousing, but to the best of my knowledge the front of the bellhousing where it attaches to the engine is different between the inline 6 and a V8. The transmission will bolt right up to a V8, but you'll need a bellhousing from a V8.
Old 09-28-2010, 11:21 PM   #3
raycow
Re: 63, 4 speed ..
63-up 6 cyl engines take the same bellhousing as the V-8, except for the 235s used in early production K-series trucks.
Ray
raycow is offline   Reply With Quote
Old 09-29-2010, 12:17 AM   #4
Heater63
Heater63's Avatar
Re: 63, 4 speed ..
Like RayCow said. 63 should be the same as SBC and BBC.
For a manual tranny with overdrive, there is only one inexpensive but fairly light duty way to go, a T5. Brad and others on this board have good threads on that approach. Behind a 230 it is fine, even the non world class ones, and you can have overdrive for maybe $500 or so.
For more $$$ you could add an overdrive unit, like Gear Vendors, or do like me and put in a new Tremec TKO ($$$ also) that will handle HP and torque up to 500 or 600 ft/lb if you plan on a bigger V8 in the trucks future.
292 + TKO500
Heater63 is offline   Reply With Quote
Old 09-29-2010, 12:24 AM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
Re: 63, 4 speed ..
Thanks for the clarification. It's been many moons since I've owned an inline six.
Old 10-02-2010, 03:42 PM   #6
1942
Re: 63, 4 speed ..
Thanks good to know!
Old 10-03-2010, 08:40 PM   #7
Turkey
Turkey's Avatar
Re: 63, 4 speed ..
Been needing some tranny info. Perfect timing!!
Turkey is offline   Reply With Quote
Old 10-05-2010, 12:31 AM   #8
ANoodle
Re: 63, 4 speed ..
That is exactly what I was wondering too. Thanks
ANoodle is offline   Reply With Quote
