09-28-2010, 06:38 PM | #1 |
Lemme show you something!!
Problem w/ Door Hinge.
Hi ya'll....finally got the cab in a place where I could re-hang a door to check gaps and whatnot. Here's the problem(s).
1. The top outside bolt on the upper hinge hits the hinge plate and won't let the door shut all the way. Everything is tight and aligned, so I'm wondering if anybody has run into this issue and what they did about it. 2. The door gap on the latch side of the door is about 3/8"! I have the door slid back on the pillar as much as I can. Do I; a. Do the Kevin Lewis (rokcrln) thing and weld some .125" filler rod along the edge of the door? b. loosen the door-to-hinge bolts and slide in some shim plates to move the door back some more?
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
09-28-2010, 07:36 PM | #2 |
Re: Problem w/ Door Hinge.
I have no clue on that but ill give you a Bump
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
09-28-2010, 10:23 PM | #3 |
Back in the sticks
May sound crazy, but are you sure you didn't mix up the hinges? Driver/Passenger? I've done dumber stuff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
10-21-2010, 09:19 AM | #4 |
True Addiction
I am having a similar issue. Could anyone provide a few photos of the proper hinge configuration.
Thanks!
RCC |
10-21-2010, 11:08 AM | #5 |
Same thing happened to me and i noticed i was using the wrong bolt for that hole. Don't know if all were like that but there is one different bolt in all mine.
10-21-2010, 12:26 PM | #6 |
Just checked my trucks passenger side hinge. and the hinge in the photo looks correct compared to mine. did the door ever close correct? check the cabs hinge mounting point to make sure its not tweaked a little. or the front edge of the door isn't bent. I had a door that was really giving me fits and thats what was my problem was. I would (not a pro) pull the door off and really check it out maybe even look into a new hinge set up. not much money and then you will know for sure where your at . hope this helps cheers, Pat P.S. these trucks were built at the time to be( work trucks) so at gm the door fit was never as good as todays standards jmo,
10-21-2010, 06:27 PM | #7 |
Did you rockers and corners? If so was the cab cut loose off of the frame? The jamb could have shifted on you, especially if the floor was weak or non-exsistent. There should not be a "special" bolt for that hinge. Your hinge is in the right spot and location (lft/Rght) so that is not a problem. I would check the the hinge pocket to be sure it is not bent out - someone opening too far at some good point or even the wind blowing too far over. You can use a 2x4 to sink the pocket a little to get the clearance you need, it is a miracle tool . As far as your gap the rod thing is your best bet, but on a set of doors I had on a 69 I actually built mig weld bead down the door edge and then ground it to the gap i wanted- use a flap disc when doing this to keep heat down. Shims behind the hinge are a good idea and can be used if you have room in the upper door opening, but if you dont it will not work to close the gap up as much as you want.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
10-23-2010, 05:57 PM | #8 |
With the bolt issue, same exact thing happened to me. I just had to grind the bolt head down a tad and problem solved. I thought it happened to me because I noticed my aftermarket hinge was slightly thicker than stock, but it looks like you are using a stock hinge.
10-23-2010, 06:23 PM | #9 |
those look like aftermarket hinges and they are 2 thick and wont work.......rebuild originals
10-23-2010, 06:24 PM | #10 |
Project Junkie! Fishing Poor!!
It would seem that all of the aftermarket hinges any more are thicker than the originals. I do not like them, I rebuild the originals in stead. Your hing looks like an original and the only time I have seen the problem that you are having is when the wrong bolt is being used. Just grind the head a little and your problem will be solved. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
