8-400 badge...what exactly does it mean?
Just want to make sure of something. the 8-400 badge came out in 71 for the big block trucks even though they were infact 402ci, and, eventhough the '70 trucks were 402's, they still got the 8-396 badge correct?
And, the small block 400 was never offered in the pre-'73 trucks, true? I ask because I might buy this truck below (for the motor and tranny, and onl y if I can get it cheaper) and can't quite make out the size of the motor in the pic, and I think it is a '72, not a '70: http://minneapolis.craigslist.org/hn...955810491.html
1971 C-20 350/350 |
Roadtrip!
![]() Join Date: Feb 2003
Re: 8-400 badge...what exactly does it mean?
That is a 72 big block. (402) In 1970 they were badged as 400 thru 72.
And you are correct the 400 small block wasn't offered in these trucks. That looks like a good buy. Better hurry, won't last long.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
#3 | |
![]() Say, this ad in craigs is from your neck of the woods...you thinning the herd? 1967 chevy shortbed parts truck - $500 (Grand Rapids)
1971 C-20 350/350 |
#4 | |
![]() Join Date: Nov 2007
I would buy it
72 C20 Longbed 05 1500 Z71 Last edited by sleepertruck72; 09-29-2010 at 01:42 AM. |
Roadtrip!
I have been thinning the herd for over a year now. Still have a few to go... And yes, that is one of mine.
Cool, good to know. You have a bunch of parts too, or just some carcasses left? I'm in the market for a few things...
1971 C-20 350/350 |
So, if the guy doesn't have a key for it, how am i to get it running? bridge a wire from the battery to the starter? then likewise, how do i get it to stop running? block the carb?
Or is there an easier way?
1971 C-20 350/350 |
#9 | |
72 C20 Longbed 05 1500 Z71 |
Looks like it has a tilt column also...
67 Chevy K20 LWB Fleetside project 85 GMC K10 High Sierra LWB, 37's, 8 lug rears, 4.10's project 86 m1009 blazer, 6 in lift, 35's, driver 69 c10, 307, long bed, 3 speed, driver 07 Dodge 2500, cc, lb, cummins turbo diesel 00 z28 camaro, ls1, 6 speed, rarely leaves the garage |
It does! the guy just sent me more pictures and it looks pretty good...now i am getting excited ![]()
1971 C-20 350/350 |
I'm new around here, but I'm pretty sure that the screw in the upper part of the door, just below the vent window handle tells you it's a 72. Obviously, that's assuming it's all original, but it's a start. Someone correct me if I'm wrong on that one...
Derek 72 Chevy Cheyenne Super LWB 454 SS LS6 90 GMC Suburban V2500 350 ----------- 64 Chevy El Camino 357 73 Jeep Wagoneer 360 78 Jeep Cherokee 360 79 Scout II 345 88 Jeep Wrangler 4.2L 91 Jeep Wrangler 4.3L 98 Lincoln Mark VIII 4.6L 01 GMC Yukon 5.3L "If it's not broken, fix it 'till it is!" |
#13 |
![]() Join Date: Apr 2010
Its a 72. He sent me the VIN and a couple of pictures.
ROD ![]() 1969 K10 4x4 Short Fleet. Tuned Port Injection 350/700R4, Cruise, tilt and factory A/C. 1971 C20 Camper Special. 350/350. SOLD 2002 Chevy Tahoe LT Last edited by Rodk65; 09-29-2010 at 05:42 PM. |
#14 |
![]() Join Date: Apr 2001
BUY IT before i have to!!! bb, tilt, D60, fact aux tank, vintage turbines... needs a hom eto some one on this board...
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
#15 |
I'm thinking about it. I'm trying to figure out what to do about the title, or just switch cabs. Just have to make the 5-6 hour road trip.
ROD ![]() 1969 K10 4x4 Short Fleet. Tuned Port Injection 350/700R4, Cruise, tilt and factory A/C. 1971 C20 Camper Special. 350/350. SOLD 2002 Chevy Tahoe LT |
#16 |
If you are just going to use it for parts I'd just take a screwdriver and knock the ignition out and start it like tht I think it would work I drove my 85 3/4 ton and my 78 elcamino with a screwdriver for a key for a while
#17 |
If you only want to see if the engine will start, run a wire from the battery (+) to the ignition coil (+). Then jump the starter solenoid (bat to S terminal) with a heavy screwdriver. If you want to do it "nice", clip a remote starter switch onto the solenoid instead of using a screwdriver. Don't run the engine for very long like this if the distributor still has points, because they will burn very quickly.
If the distributor has points and you want to run the engine for an extended length of time, connect an external coil resistor in series with the battery to coil wire. Ray Last edited by raycow; 09-29-2010 at 08:21 PM. |
#18 | ||
1971 C-20 350/350 |
#19 |
Well friends, I got it
![]() I didn't get it started because it has points and I didn't want to fry them, so I took a leap. The oil wasn't too dirty, and the trans fluid was clean as can be. The tilt wheel is tight, all the AC components are present except the compressor it seems, and the frame doesn't look NEARLY as bad as the body. The cab and bed are pretty rotten, and the old turbines (9.5x16.5) are 'ok' but the tires are shot/missing ![]() It isn't as nice as I had hoped, but I am going to see what I can do to improve that. I am going to clean it tip to tail and get it running. then i will decide if I want to re-sell, or part it, or put the body of my 71 on this frame/drivetrain. ![]()
1971 C-20 350/350 |
#20 |
more...
1971 C-20 350/350 |
#21 |
I'm glad someone went to get it. Were any of his other truck any good?
#22 |
The '70 c-20 was ok, probably the same level as this truck, and I didn't look to closely at the '64's, except the c-20 dually looked like it was a 67-72 coil rear frame with a dually HO72 rear axle, no box.
This guy is retired and gets 2 to 10 cars daily from people that are running estates or want to clear up the clutter on their farmstead. he generally just scraps them @ about $175 a ton unless they are unique/in better shape than normal. Funny thing...i had just loaded the truck up on the trailer and parked it on the service road next to the freeway to then settle up with the seller, and some dude pulled off the freeway and stopped by my truck. he then went on to say that he saw the truck loaded up and had to stop because he has a '67 small window short box sitting at his place that he wants sold. We exchanged contact info and I said I would post some pics here for him if he'd like. we'll see if he emails me... These trucks are waiting for us obsessive bastards all over the place ![]()
1971 C-20 350/350 |
#23 |
Roadtrip!
Glad someone from here got it. Did you get a deal? Lots of good parts there...
#24 |
GOOD JOB!!!! I wasnt looking forward to marraige counselling if I diverted our trip to the twins game yesterday to go look at it
![]() --Mike
#25 | ||
Got it cleaned up today... there was moss EVERYWHERE:
1971 C-20 350/350 |
