Old 02-26-2003, 08:59 PM   #1
Reumster
L.E.D. Freak
Reumster's Avatar
Question Bought bags/Bag Pro's?/Wiring valves?/Custom Push button momentary switches?
I have my bags and switches, tanks etc... need advice for install.
My question is can I run the ground to the push button momentary switches instead of the power wire?
Also anyone know where I can get nice billet LED "mini" pushbutton momentary switches?
REAR BAG SPACERS? NOT ANOUGH LIFT
maxium lift problem? Without a c-notch I noticed that the bags will not compress all the way when the u bolts are sitting on the cut factory bump stops. My idea is to shim the rear bags untill they are like a 1/4" from bottoming out the bag. When sitting on the rear bump stops. Then I will acheive maxium travel and lift out of the rear bags? Then when I get my c-notch I'll take the shims/spacers out from under the rear bags.
What are all your thoughts on this?
I will be taking alot of pictures of the install.
I bought bags, valves and compressors from Larry at Innovative
http://www.innovativeairsuspension.com/
And a bunch of stuff from Dave at Early Classics
http://www.earlyclassic.com/
hidden hitch, panhard kit,shock relocator kit.........
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
Old 02-26-2003, 10:43 PM   #2
Reumster
L.E.D. Freak
Reumster's Avatar
Help Slammed 67/XXL? Bag guys? Throw me a bone here people! LOL
(406)675-8082
Old 02-26-2003, 11:17 PM   #3
Slammed67
Progress = 0%
Slammed67's Avatar
Yeah, you can shim up the rear bags. I think some kits come with brackets for the rear bags, which will raise them also. Did you buy a kit or are you going to make up your own brackets? I think you'll find that without shimming up the rear bags, the front will sit higher than the rear at ride height anyway. That is the problem I'm encountering. I could shim my rear bags up, but I want maximum DROP, not maximum LIFT. Therefore, I'm gonna notch my front cross member to bring the front down a little to even it out. As for wiring the switches, you could run the grounds to the switches, but it'll be the same amount of wire, so I'm not sure what the advantage is.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 02-26-2003, 11:17 PM   #4
orange72
orange72's Avatar
why does it matter if the bag is bottomed out or not? its not gonna make a difference
1972 chevy long bed. Currently under construction!! Bagged, 383/700r4.
orange72 is offline   Reply With Quote
Old 02-26-2003, 11:47 PM   #5
orange72
orange72's Avatar
oh i think i misunderstood that question
Old 02-27-2003, 01:23 AM   #6
pissonNOS
senior member
pissonNOS's Avatar
i think you did haha have to post pics when u get it done
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 02-27-2003, 10:29 AM   #7
Reumster
L.E.D. Freak
Reumster's Avatar
TTT
(406)675-8082
Old 02-27-2003, 11:31 AM   #8
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
On running the ground, if the solonoids have only one wire you will have to isolate them from the body, for the case is how it is designed to get its ground, if it has two , then its a matter of running a all time hot and putting a switch to ground to complete the curcuit
sneakysnake is offline   Reply With Quote
Old 02-27-2003, 04:41 PM   #9
Reumster
L.E.D. Freak
Reumster's Avatar
Arrow
Picture of my valve set-up.
What your looking at are 3/8" valves, using high pressure crimp on 5000psi hose. The fittings are JIC/AN which ever term you use. #6 hose, and or 3/8"
I plan on the front using 1/2" valves and hose.
(406)675-8082
Old 02-27-2003, 04:47 PM   #10
Reumster
L.E.D. Freak
Reumster's Avatar
Ok I'm letting you all in on my new idea. This is my secret switch box. The board the mini momentary push button switches are mounted to is, G-10 Garolite black. This is just what I had at the time. I'm going to be using Carbon fiber eventually.
(406)675-8082
Old 02-27-2003, 04:49 PM   #11
Reumster
L.E.D. Freak
Reumster's Avatar
This is the ashtray out, and a sample piece of the Carbon material I'll be using, for the final product.
If anyone is interested I can whip these ashtray inserts up. My problem now is finding good quality mini push button momentary switches. I'd like to find billet ones.
(406)675-8082
Old 02-27-2003, 07:04 PM   #12
Reumster
L.E.D. Freak
Reumster's Avatar
These Radio Shack switches in the picture in the ashtray suck! They stick. I need lower profile ones too. Anyone know where to get good ones? I can't wait to get my ALuminum tanks tommarrow. Then it's time to test.
(406)675-8082
Old 02-27-2003, 08:29 PM   #13
Slammed67
Progress = 0%
Slammed67's Avatar
Just curious....... Why not just use DOT approved air line and push-in fittings? I would think it'd be cheaper and easier to install than what you are using.
Old 02-27-2003, 11:47 PM   #14
XXL
Seņor Member
XXL's Avatar
Thread hijack alert...
I just lost one corner of my air ride today. The right rear "up" is not responding. It's definitely the solenoid itself. I had this happen once before (when I first moved to MA in winter 2001) and Air Ride Technologies promptly replaced it with a brand new piece. I've pinged them via email about what to do with the one that's sticking now but I suspect they're going to tell me it's OOW (out of warranty). So... questions arise-- 1) has anyone else had this kind of failure problem, 2) what kind of valves should I use if I decide to toss the ART ones I have now, and 3) what's for lunch?
I don't even dump the truck that often... maybe a couple of times per month, but I would like it to be VERY reliable (which it has been for the most part for the last 3 1/2 years).
OK, next related topic. My pressure switch died as well. Any suggestions for an inexpensive 120 psi or so switch?
BTW, for this whole thread, I suppose I should add... the truck is kept in a 50° garage-- except today, when I high-centered the truck on some snow in front of the garage. I was backing out and got it stuck on the center crossmember, so the truck sat half in and half out of the garage all day. It was about 25° F today. It is now back in the garage, hopefully getting warm and toasty.
Kenneth
XXL is offline   Reply With Quote
Old 02-28-2003, 01:54 AM   #15
JHickson6
I Love This Stuff!
JHickson6's Avatar
Hey i'm a little late here, but I just have a question for Slammed67, you said the front will sit higher than the rear at ride height. Why is that, what about putting more air in the rear bags to level it out? Or am i missing something here?
Thanks Man
Jared
My Rides
1967 C10 In Pieces for now
1985 Ford B700 SourPuss Bus - BIG BLUE
2003 Silverado CITY WORKER YELLOW!!
JHickson6 is offline   Reply With Quote
Old 02-28-2003, 01:57 AM   #16
pissonNOS
senior member
pissonNOS's Avatar
REUMSTER what kind of deck is that?
69 GMC bagged
Old 02-28-2003, 02:09 AM   #17
Dropt72Shortbed
Dropt72Shortbed's Avatar
Kenneth
have you drained your tank to see if theres any moisture in it? im not positive but i recall hearing that moisture in the system can hurt some types of valves, i think some guys use water traps/seperators. however here in california none of my friends use em and they have no problems.
Dropt72Shortbed is offline   Reply With Quote
Old 02-28-2003, 10:23 AM   #18
Reumster
L.E.D. Freak
Reumster's Avatar
Thumbs up
Ok now we're getting some knowledge on in this topic.
Slammed67 to answer your question about the crazy over kill hose. FREE!!!! LOL I made them at work. So you think the 4 wire hydralic hose is a tid bit overkill!! LOL Cheaper but not easier to install.
XXL my valves are SMC that I got at http://www.innovativeairsuspension.com/
XXL did you put air tool oil in your compressor hose when you installed the comp for the first time? also put a drop or two in each valve on the in side before installing. Do you have drain valves on your tank/s? Do you have a oil/water seperator?
Next I found some cool air gauges that I'll post pictures of soon.
Any ideas on good temperary micro push button switches?
(406)675-8082
Old 02-28-2003, 03:19 PM   #19
Slammed67
Progress = 0%
Slammed67's Avatar
JHickson6:
I could put more air in the rears but then it rides too rough. I could lower the front air pressure, but then again, I'd compromise my ride height. I could also shim my rear bags as Reumster mentioned, but then I'd lose my maximum DROP, which is one of the main reasons I got the bags in the first place. So the only solution I see is to drop the front more to level it out. I like the rear height at "ride height" so I'm gonna bring the front end down to match. Make sense?
Old 02-28-2003, 09:39 PM   #20
SCOTI
SCOTI's Avatar
Ok, I learned this from XXL so you can blame him (how to hi-jack)....j/k.... Slammed, I'm curious, what psi are you running & what are the measurements @ the c/l of your wheel openings @ ride height. I want to compare to my set-up. Thanks, Scot
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-28-2003, 10:31 PM   #21
XXL
Seņor Member
XXL's Avatar
Speaking of thread-jacking... various drop measurements are in this old thread which I managed to hijack as well. Oops.
BTW, here's Slammed67's in action...
Kenneth
Old 02-28-2003, 10:43 PM   #22
DanoDMano
Pronounced "Pew-al-up"
DanoDMano's Avatar
Way cool XXL!!!!!!!!
Classic GM Trucks of Washington Club Member
1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's,
Power Locks,
Truck Photos
DanoDMano is offline   Reply With Quote
Old 02-28-2003, 10:47 PM   #23
XXL
Seņor Member
XXL's Avatar
That's Slammed67's truck and his photos. All I did was string them together.
Kenneth
Old 02-28-2003, 10:57 PM   #24
DanoDMano
DanoDMano's Avatar
Slammed67, that is an awesome looking ride!!
Power Locks,
Truck Photos
Old 02-28-2003, 11:20 PM   #25
JHickson6
I Love This Stuff!
JHickson6's Avatar
Thanks Slammed it all makes sense now. Thanks Again!
My Rides
