09-29-2010, 02:01 PM | #1 |
Dual Exhaust
Could someone post some pix of how they routed their dual exhaust on their 4x4? I am wondering how to run the pipe pass the front driveshaft and transfer case on the passenger side. I would like to keep all the pipes above the bottom of the frame.
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=407865 |
09-30-2010, 07:55 PM | #2 |
Re: Dual Exhaust
My buddy Nick cut some steel for me according to a template he and I made to cover the hack job done on my cross member before. After welding, grinding, and a wee bit of putty, it turned out very nice.
09-30-2010, 10:47 PM | #3 | |
Re: Dual Exhaust
I can post a pic tonight or tomorrow how mine was done, i have a 3/4T 4X4. I can tell you it snakes between the transfer case and frame rail, tight squeeze there were no cross brace mods done so different from the other pic's posted..
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's Last edited by swamp rat; 09-30-2010 at 10:49 PM. |
10-01-2010, 01:49 AM | #4 |
Re: Dual Exhaust
kinda depends on the year/ body style of your truck too... i know i ran dual 3" on my '84 1/3 ton 4x4 and it was a little tricky but it went up and over the transfer case with kind of an "S" shape bend. i know this isn't the greatest picture, but if you look at the header/exhaust on the right side it is sitting exactly how it was hanging in the truck.
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you." '84 chevy half ton short box 2wd, 67,000 actual miles '03 chevy 1500 HD crew cab 4x4 standard box, 6.0L |
10-01-2010, 02:01 PM | #5 |
Re: Dual Exhaust
Heres the best pic's i got, ya need to dissregard my temporary fix tho as the pipe was barly clearing the case and when it idled it would rattle against it, got a little annioying so i made a home made "puller" clamp to pull it away about 1/8". It starterd doing that after about 7 years, somehow it decided to sag downward a little i guess
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
10-01-2010, 02:44 PM | #6 |
New Member
Re: Dual Exhaust
Here's a pic from my Blazer. Not dual all the way back but it goes through the same area up front. There is room to make it happen.
10-01-2010, 07:45 PM | #7 |
Re: Dual Exhaust
Here's a picture of mine with the cab off. There is room there. Those are 2 1/2" pipes. Ignore the pipes heading outside the chassis, I squeezed some propane tanks in.
1972 K2500 Long Box 400/350 |
10-01-2010, 10:40 PM | #8 | |
Re: Dual Exhaust
EDIT: Oh yea, like the way your pipe is routed way better than my $100 rush rush under the table job..
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's Last edited by swamp rat; 10-01-2010 at 11:23 PM. |
10-01-2010, 10:51 PM | #9 | |
Re: Dual Exhaust
Hmmm.............. |
10-02-2010, 12:20 AM | #10 |
Re: Dual Exhaust
Yup, propane X 2.
10-02-2010, 12:32 AM | #11 |
Re: Dual Exhaust
Ya know i was kinda wondering about some gas tanks in the same area, but my next thought was about safety and the possibility of breaking a U joint and having the driveline smack a tank, was then thinking about a driveline cage just in case... Of course this is just thinking about possibilitys, and your build is the closest i have seen to what i was thinking. Nice!
Could i talk you out of a pic of the rear of the frame from the back too? EDIT, Sorry for the hyjack,,
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's Last edited by swamp rat; 10-02-2010 at 02:26 AM. |
10-02-2010, 01:30 AM | #12 |
Re: Dual Exhaust
No problem. You can see my driveshaft hoop in the first pic. LPG regs down here say if you are closer than 8" to the tank you must have a hoop. Funny thing is there is no comment on how close to the driveshaft you can get. Excuse the off topic Travis.
10-02-2010, 09:07 PM | #13 |
God is good!
Re: Dual Exhaust
I was wondering the same thing. I want to run duals out of exhaust manifolds on a '73 longbed 4X4 and was curious as to how anyone could run the pipe over on the passenger side. Seems like starter R&I would be impossible without having the pipe run too low. I, too, want to run them above the frame. How in the heck did the factory do it???
10-02-2010, 11:14 PM | #14 | |
Re: Dual Exhaust
10-03-2010, 06:26 PM | #15 |
Sb 400 club
Re: Dual Exhaust
I just ran the dynomax kit on my 77 K10. Donno if they make a similar kit for your year. Worked well. Just be prepaird for warm floor boards!!!
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
10-04-2010, 12:24 AM | #16 |
Re: Dual Exhaust
Thanks for the pix guys. I was looking at the chassis without the cab on, and wasn't taking into account that the cab sits above the frame rail a couple inches. Anyone know how far I should keep the pipes away from an aluminum fuel cell, and if they get too close, what problems could I run into?
10-04-2010, 12:34 AM | #17 |
Re: Dual Exhaust
Donno the answer but would also like to know cause i have an alum fuel cell in route as i type.. need to rework my exhaust.
10-04-2010, 12:58 AM | #18 | |
God is good!
Re: Dual Exhaust
I don't think you'll have any problems but you may want to look into putting a heat shield on the tank and/or the pipe. The exhaust systems on most new cars sit very close to EVERYTHING so they have heat shields all over the undercarriage. |
10-04-2010, 01:14 PM | #19 |
New Member
Re: Dual Exhaust
How far back is the fuel cell? If it's towards the back the tail pipes won't get that hot to worry about.
