Old 09-29-2010, 06:10 PM   #1
erick-1
erick-1's Avatar
Super T-10 info..??
I'd been doing research in the forums but no luck, can't find useful information at all. What I'd like to know is that is it possible to install one of this transmissions behind an I-6 engine? If so, what parts should i be looking for? Also, what would be better, short or wide ratio, my truck currently has a 4 speed granny-low with 3.07 rear end.
erick-1 is offline   Reply With Quote
Old 09-29-2010, 07:15 PM   #2
LONGHAIR
Re: Super T-10 info..??
You want the widest ratio you can get, especially because of the 3.07s. You need the lower first gear to get it going. It won't be super low like your granny gear transmission, it's actually a usable gear.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 09-29-2010, 07:46 PM   #3
raycow
Any ST-10 for a GM app will bolt to your stock bellhousing. If you get one with a 26 spline input shaft you will need to replace your clutch disc. If your bellhousing is 68 or later you will need a centering ring, which is about a $30 part, or you can make it yourself if you have access to a machine shop. Besides that, you will need to replace or modify your driveshaft if you are replacing a truck type 4 speed.
A wide-ratio version would be the best match for your 3.07 rear.
Ray
raycow is offline   Reply With Quote
Old 09-29-2010, 11:09 PM   #4
erick-1
erick-1's Avatar
ok thanks, do you guys know how to identify a wide-ratio ?? Is it by the number of grooves in the input shaft. A 3.42 first gear ratio should be enough right?
Old 09-30-2010, 04:51 AM   #5
raycow
Yes, count the grooves on the input shaft. A 3.42 ratio will have 6 grooves.
http://www.dandltransmission.com/borgratio.html
Ray
Old 09-30-2010, 11:02 AM   #6
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
Ray
that info isn't entirely correct, my t-10 has 6 grooves on the 26 spline input and doesn't have the 32 spline output, mine has the 27 spline output. came from a 82 slow-maro.
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 09-30-2010, 01:09 PM   #7
raycow
But does the transmission have a 3.42 1st gear?
Ray
Old 09-30-2010, 02:32 PM   #8
vasquezmrysvll
"the other guy"
after seeing this info im not too sure? 6 grooves on input with 27 spline out put? HHHMMMMMMMM?
