Old 09-29-2010, 07:15 PM   #1
acl
acl's Avatar
power steering help please
This will be long, I'm sorry. I am atempting to put power steering on a 68. I have put on a used steering box as well as 5 p/s pumps. They all will not stop whining and is not smooth steering when driving. I have put on a second used p/s box with the same results. I have had fluid "foam" out of the top of the pump cap 2 different times (never seen that before). I am lost. If a new box will fix this I will spend the $250.00 but I would like some opinions before I drop that much. I have primed the pump (turn w/fluid before belt is installed) New hoses no crimps. Any help. If I had this much prob with my first truck i might not be working on the second one. Thanks Gary
acl is offline   Reply With Quote
Old 09-29-2010, 08:18 PM   #2
raycow
Re: power steering help please
It sounds like you may have air in the system. Jack both front wheels off the ground. Then start the engine and turn the steering wheel back and forth through its full travel several times. If the fluid level goes down, refill it and repeat the wheel turning until the fluid level remains constant.
Ray
raycow is offline   Reply With Quote
Old 09-29-2010, 08:24 PM   #3
brans72
agree with Ray sounds like air is in the system.
brans72 is offline   Reply With Quote
Old 09-29-2010, 08:53 PM   #4
acl
acl's Avatar
hey thanks for the response. I have tried that a couple times for 5 to 10 min. did not help. any one ever break loose the pressure hose while running?? thanks for the help. Gary Sorry , I mean breaking it loose to "bleed" the air?
Old 09-29-2010, 09:00 PM   #5
jay6891
Car Knocker
jay6891's Avatar
Dont think I would break the hose loose. Good way to at the very least take a bath. Worst case, hand in a pulley or a fan. What the guys are telling you is sound advice. I would turn semi-slow to keep the fluid from foaming. Never had problems like you are saying. Good Luck Man
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 09-30-2010, 08:17 AM   #6
acl
acl's Avatar
thanks jay, will try turning lock to lock again. Would air in system make it choppy when turning also. It will turn and "hang up" and turn some more. any other ideas. Thanks Gary
Old 09-30-2010, 09:04 AM   #7
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Everything you are describing...hanging, whining, foaming are all the symptoms of air in the system. I did mine with the engine off turning the wheels lock to lock for a good number of times, then a few with the engine running until the fluid level stopped dropping, also remember to do all this with the reservoir cap removed as this helps let the air escape.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 09-30-2010, 09:40 AM   #8
acl
acl's Avatar
i will try some more. with it already foamy do i need to do anything else or will the foamy air in system go away? Thanks Gary
Old 09-30-2010, 11:34 AM   #9
eightbanger
454 MAKES IT ROAR
The foam should settle, the main reason I think for the fluid turning foamy is that it is getting hot, thats why its better turning the wheels back and forth to purge the air when the Truck isn't running.
Nigel.
No more pain.
Old 09-30-2010, 12:58 PM   #10
chevy_mike
Never Ending Projects
chevy_mike's Avatar
To state the obvious, you do have the high pressure line hooked into the correct port on the PS box, correct? Just throwing that out there.
As for bleading, everything I have ever read is to have the vehicle in the air, engine off and turn the steering lock to lock about 15-20 times, and make sure the fluid level stays correct. Then do the same with the engine running. Make sure you don't over fill the fluid level as that can cause foaming issues.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 09-30-2010, 01:32 PM   #11
70STOVEBOLT
70STOVEBOLT's Avatar
I just converted mine last weekend, and I didn't jack the truck up, I just filled the reservior and then started the engine and turned the wheel very slowly from lock to lock about a dozen or so times, checking the fluid level after each few times, and the foam eventually went away. I could see bubbles coming up through the foam each time I added fluid. Power steering is great!!
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is online now   Reply With Quote
Old 09-30-2010, 02:50 PM   #12
68 short step
my thoughts too
68 short step is offline   Reply With Quote
Old 09-30-2010, 07:31 PM   #13
Little Red
Little Red's Avatar
Have to agree with Chevy_Mike as well
After 5 pumps, 2 boxes and constant bleeding with the same results, the probability of having those lines mixed up at the box is great.
In the end, after you get it all figured out, Lucas p/s stop leak works fantastic for making your steering smooth and quiet, not just for leaks.
Some days your the bug some days your the windshield!
69 C10 Stepside ~ Project
79 K10 Shortbed 4X4 ~ Sold
72 Chevelle SS Clone ~ Sold
Little Red is offline   Reply With Quote
Old 09-30-2010, 08:08 PM   #14
72lb4x4
This is strange. I've replaced the pump, hoses, and gearbox on my Camaro and K10. Both times I just filled w/ fluid, cranked the wheel lock to lock a few times, topped the fluid off and was done.
No lifting the front end, no endless bleeding.
72lb4x4 is offline   Reply With Quote
Old 10-01-2010, 10:08 AM   #15
acl
acl's Avatar
now you have me thinking about lines. But can they be put on wrong? Just di not think the hose ends would let that happen? thanks and keep other ideas coming. Looking at getting another box this weekend and trying a different pump as well. If i replace both these again i should jack it up and turn lock to lock numerous time and fill fluid as needed is this correct???? any other advice to bleed system? Thanks a bunch. Gary
Old 10-01-2010, 12:32 PM   #16
acl
acl's Avatar
Thinking if my first box was "bad" could that mess up a new pump? I have not changed pump since installing 2nd gear box. Huh Any thoughts?? Gary
Old 10-01-2010, 12:36 PM   #17
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
I thought the pump was bad on mine, but once I put in a reman steering gear, all was well. Think I got it at Autozone for less than $200. Mine never did the foaming thing like yours, it was just hard to turn like a manual.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 10-01-2010, 05:11 PM   #18
alfeefish
Did your frame have a dimple for steering box?
alfeefish is offline   Reply With Quote
Old 10-01-2010, 05:15 PM   #19
acl
acl's Avatar
yes but did have to trim bumper mount to fit. Thanks Gary
