Ok, i want to know if you can use shims/washers behind the crank pulley? The reason for this is i have after market power steering brackets. billet. The pulley on the str pump doesn't line up to the crank pulley. The str pump pulley has 2 grooves. There is about a 1/2" behind the str pump. The crank pulley has 3 grooves. Any info would be helpful. thanks.
| Bookmarks |
