09-29-2010, 08:52 PM | #1 |
Distributor ????
Looking to replace my 67's 292 distributor what are my options oh looking to put in an HEI so what do i need to look for meaning what other vehicles had an Hei distributor that would work with the 292 and what do i need to get for this to work on my 67 ie what wires plugs cap rotor thanks in advance...
09-29-2010, 09:19 PM | #2 |
Re: Distributor ????
I believe any 75 or later GM engine should have HEI. A 250 distributor should work if you can't find a 292. Also, it doesn't have to be from a truck, so look at 75-up cars too.
Ray |
09-29-2010, 10:06 PM | #3 |
i went with accel dist. and coil. cost around 200 with those two plus new plugs and wires.. my trucks a 72. and i went with an '85 setup
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
09-29-2010, 10:08 PM | #4 |
just make sure you ditch the primary wire from the coil of the points or whatever you call that wire.. i thought u just disconnect and add that to new dist. but little did i no it didnt have enough juice. so it kep giving constant power to my dist. in result would always drain my battery over night. so u got to run a new wire from the fuse box..
09-29-2010, 10:09 PM | #5 |
ha sry for so many post.. but accel the cap and rotor is all included.. and plugs i think have to be gapped at .045. and the wires are 8mm i believe
09-30-2010, 02:00 AM | #6 |
Great minds think a like. I am new and asked a similar question for my 350. I got some more info that might be helpful.
http://67-72chevytrucks.com/vboard/s...d.php?t=423533
1971 Chevy C-20 Flatbed SBC350/Turbo 350 "Torque Is Controlled Power" |
