GM Addicted
okay my speedo has always bounced around so i figured it was going bad. No it doesnt move at all. at first just the speedometer wouldnt move but the odometer would, now neither work. I have a new lower speedo cable. My truck has the cruise master unit so when i took the upper cable off the unit and spun the cable the speedo worked fine and mover perfectly with no problems. Could i have a problem with the cruise master unit internally, and does any one know if i where to disconnect the lower cable and try spinning the cable it self would it spin the speedometer gauge, if the cruis master isnt ruined. I am trying to get down to what is wrong. The transmission is new and it has a new gear internally for the speedometer. What do you guys think??
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
Re: speedometer problem
pull the lower cable off and inspect it. i bought a new one from LMC and it got ****ed up after only a couple days, so i found a used one and re-greased it
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
GM Addicted
already done that also man and its still fine
try by-passing the cruise module. otherwise try a different speedo
