Old 09-30-2010, 01:50 PM   #1
Rede
D60/D70 swap
I found a good deal on a dana60 front and dana70 rear diff from a 91 dodge...
What is all needed to use these in place of a Spicer 10bolt and a 9.5" 14bolt?
I was told that the spring perches or whatever they're called would need to be moved, but is it relatively that easy?
Or am I in for an eye opener? o_0
Rede is offline   Reply With Quote
Old 09-30-2010, 03:26 PM   #2
BIG_BLAZER86
BIG_BLAZER86's Avatar
Re: D60/D70 swap
The front springs perches are a 1/2" off,you might be able to move the perch a little to make up for the other perch on the pig.As far as the rear might have to move the perches on it,not sure.
81 blazer 2wd tukin 30's
07 Jeep Grand Cherokee on 26's
Tube chassis 5.3,dual T cases,54" boggers,steering rocks
Dodge 3500 with some mods
BIG_BLAZER86 is offline   Reply With Quote
Old 09-30-2010, 04:32 PM   #3
Rede
Re: D60/D70 swap
Do you know if I'll have a hard time with steering components?
I don't suppose my drive shafts would still work...?
Old 09-30-2010, 04:39 PM   #4
raycow
Re: D60/D70 swap
Worst case, you could need driveshaft mods both ends, steering linkage mods, and possibly some parking brake cobbling. This besides the spring perch mods. None of this is particularly difficult, but it all needs to be considered as part of the total conversion cost.
Ray
raycow is offline   Reply With Quote
Old 09-30-2010, 05:02 PM   #5
Rede
Re: D60/D70 swap
Thanks.
I'm waiting to hear back from the seller so I can take a looky and measurements.
If I take them I'll try to post up te progress.
Maybe it'll help the next person...
Old 09-30-2010, 07:07 PM   #6
Rede
Re: D60/D70 swap
Another option that keeps popping up is a 250 buck 10.5" 14bolt from the local salvage/pick a part place.
I could probably get a few bucks off for my old diff at a later date, but I'm not sure what kind of shape one of those old crusty specials would be.
So far my front diff works fine so I don't NEED to do anything it it, yet.
The idea of a matching Dana combo just appealed...
What do you guys think would be the easiest to swap and easiest both work and budget wise?
Would one of these wrecker diffs be worth a shot??
Old 09-30-2010, 07:26 PM   #7
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: D60/D70 swap
I know a D60/D70 is nice, I have that setup. But is it really necessary to go to the D60? Are you planning on running a big tire size and doing the hardcore wheeling? If the answer is no, then I would look for a D44HD and a 14b. It will be far cheaper and less of a headache. Just my two cents.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 09-30-2010, 07:36 PM   #8
Rede
Re: D60/D70 swap
No I dont need that big of diffs right away as I'm just running 33's right now.
The price just seemed good compaired to the usual $800/per diff that they usually go for here.
That and they were a matching set so no gear changes.
Do you know if the mid 70's 10.5" 14bolts are a dirrect swap for the lesser 9.5" 14bolts, or are shock mounts and such different?
