09-30-2010, 02:06 PM | #1 |
Small Block casting numbers got me going ?????
Rear casting #14010201/GM5.0LG that is supposed to be 305ci 1980-84
Front casting #V1203FDW now this is where I am confused, I can't locate the FDW suffix for this block in any documents. I only found the FD suffix and those state it is for 265ci, 283ci. Anyone got any info for this?
Mark 1967 C/10 stepside lwb daily driver 1968 C/10 fleetside lwb parts truck 1971 Cheyenne Super swb project |
09-30-2010, 05:02 PM | #2 |
Re: Small Block casting numbers got me going ?????
I don't know how accurate this page is, but it list the "FDW" suffix as an 1985 305, originally installed in a C10:
http://www.73-87.com/7387info/engineid.htm
1969 C10 SWB Project Charity Case AKA "Roscoe" 1971 Cheyenne Super A Combined Effort The Service Station-A practical ministry for those in need |
09-30-2010, 05:49 PM | #3 |
Grandpa in the rustmobile...
ive alwasy used the codes on the rear drivers sdie under cyc. head?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
09-30-2010, 07:15 PM | #4 |
Those are stampings. Casting numbers are raised.
This page should help : http://www.nastyz28.com/sbchevy/sblock.php
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
09-30-2010, 08:04 PM | #5 |
As I did in my initial post, I am trying to find the so called, rest of the story with the suffix stamps. The casting is usually a vague description of the blocks usage, since many blocks with the same casting were used for multiple applications; I believe you can narrow this down by searching the suffix stamp on the front of the block.
09-30-2010, 08:06 PM | #6 | |
09-30-2010, 08:07 PM | #7 | |
09-30-2010, 08:26 PM | #8 |
84 305
http://www.chevymania.com
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa Last edited by JDL; 09-30-2010 at 08:26 PM. |
