Old 09-30-2010, 02:42 PM   #1
jwa76fleetside
jwa76fleetside's Avatar
uh oh
engine tickin (loudly) right along with acceleration.....please oil change do the trick.....fingers crossed.
76 Chevy Fleetside
63 Lincoln Continental w/ Ford Racing 460 (550hp)
2012 VW GTI
2013 Escalade
2008 Harley
jwa76fleetside is offline   Reply With Quote
Old 09-30-2010, 03:12 PM   #2
irishman999
irishman999's Avatar
Re: uh oh
That sucks man, its not a rocker?
irishman999 is offline   Reply With Quote
Old 09-30-2010, 05:22 PM   #3
jwa76fleetside
Re: uh oh
not quite sure yet.....
76 Chevy Fleetside
2012 VW GTI
2013 Escalade
2008 Harley
Old 09-30-2010, 05:32 PM   #4
jwa76fleetside
Re: uh oh
never order a repair manual before....how are chiltons? anyone use?
76 Chevy Fleetside
2012 VW GTI
2013 Escalade
2008 Harley
Old 09-30-2010, 05:38 PM   #5
PRattenbury
Re: uh oh
Chiltons don't impress me. I go for factory manuals.
PRattenbury is offline   Reply With Quote
Old 09-30-2010, 05:49 PM   #6
jwa76fleetside
Re: uh oh
whoops....ordered the chiltons...oh well prob will suffice
76 Chevy Fleetside
2012 VW GTI
2013 Escalade
2008 Harley
Old 09-30-2010, 09:09 PM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
Re: uh oh
i've used duralube during an oil change and it helps get rid of ticking in some cases
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 09-30-2010, 09:15 PM   #8
nbpro
Re: uh oh
I go for factory manuals. all so
nbpro is offline   Reply With Quote
Old 09-30-2010, 09:18 PM   #9
PRattenbury
Re: uh oh
Mine makes some unfriendly noise in the upper RPMs. At this point, I'm gonna check the valve train one more time. If it all looks good, I'm just gonna run it till it pukes.
Old 09-30-2010, 10:27 PM   #10
dccarpenter
Re: uh oh
Might want to try using a thicker oil and Motor Honey additive, it really made a difference in my truck. Also see if you are getting blow-by (is it leaking oil from the gaskets? popping the pvc?) I was able to fix a lot of my problems by getting an oil fill breather cap and using 10w40 oil. I know the oil's a band-aid, but if it's a 30,000 mile band-aid that's 2 years with the mileage I drive.
dccarpenter is offline   Reply With Quote
Old 09-30-2010, 10:50 PM   #11
BigBlocksRule
Re: uh oh
Are you sure it's not an exhaust leak?
BigBlocksRule is offline   Reply With Quote
Old 10-01-2010, 08:01 AM   #12
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: uh oh
Was my thought as well. I had an awful tapping noise with only 200 miles on my engine. Found the left header had a bolt missing, 1 finger tight and the rest barely holding on.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 10-01-2010, 12:49 PM   #13
Cue-Ball
Cue-Ball's Avatar
Re: uh oh
I would also check for an exhaust leak. If you can't hear the tick at idle or low RPMs, but you can hear it under load, that's a good indication of a leaky exhaust manifold gasket.
Cue-Ball is offline   Reply With Quote
Old 10-01-2010, 12:55 PM   #14
jwa76fleetside
Re: uh oh
thanks i will look at the manifolds tomorrow
76 Chevy Fleetside
2012 VW GTI
2013 Escalade
2008 Harley
