09-30-2010, 05:53 PM | #1 |
Grandpa in the rustmobile...
Show me your sparkplug wire routing/looms!!
Post how you routed your plug wires, Zip ties? fancy looms lets see em!
(trying to get ideas for myself, centerbolt heads, ram horns)
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
09-30-2010, 06:14 PM | #2 |
Re: Show me your sparkplug wire routing/looms!!
here are a couple of picts of mine..
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
09-30-2010, 06:19 PM | #3 |
Champagne Taste on Beer Budget
Dang Big Al !! ! That is one clean looking engine bay!
oldblue1968chevy - I think what you are going to find out with your Ramhorn exhaust manifolds that you will be very limited on how you can route your spark plug wires. Good luck. There are some very creative folks here and someone may be able to share some pictures of what they have come up with.
Coming Soon: Project 1970 Country Truck |
09-30-2010, 07:23 PM | #4 |
A couple of mine. I haven't taken the time to organize at the dizzy yet, but I do like the looms.
09-30-2010, 07:52 PM | #5 |
Who's got steelies?
Here is a picture of how I had mine routed for a long time:
I have since gone to a factory-style set up of the wire routing. I used '75 vette wires to get them the right length, though you'll have 1 wire too short if you use all the 67-70 factory looms. If you've got a throttle cable instead of a rod, and use the 71-72 stuff, I bet it will come out perfect.
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
09-30-2010, 08:09 PM | #6 |
Kind of off topic, but I'd like to know the color blue you have on your truck its awsome! Above poster that is. I just zip tie them because its still a wip and when I get the crate motor in there ill run them factory style.
Posted via Mobile Device |
09-30-2010, 08:24 PM | #7 |
sharp as a marble
I ran mine on my truck and Blazer like a 75-80 Corvette. The front two on both side run down, and come up thru the motor mounts. Clean and almost unnoticed.
09-30-2010, 08:28 PM | #8 |
Who's got steelies?
Thanks! Its Rustoleum Sail Blue
10-01-2010, 09:44 PM | #9 |
Here's how I ran mine, with 75 Vette wires for HEI. Hope this helps?
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
10-01-2010, 11:45 PM | #10 |
Im upgrading to cable throttle anyways...
So vette wires are ok on a mild 350? (see sig)? cable throttle, 71 72 facotry looms, vette cables 1975
10-02-2010, 12:15 AM | #11 |
My Carbon Footprint
okay
10-02-2010, 04:10 AM | #12 |
Here's what I've got. Not sure it will work with the ram horns though.
My build thread. |
01-14-2011, 03:38 AM | #13 |
11-04-2016, 01:45 PM | #14 |
Hello, I have a question and hopefully someone will help. I am really digging those looms that run beside the valve covers but will the typical "over the valve cover" plug wire be long enough to run in the looms? Thanks for any and all help.
11-04-2016, 04:22 PM | #15 |
went with ceramic plugs for the heat.
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
11-04-2016, 05:01 PM | #16 | |
motor exploder
I've tried the 90* boot Pertronix Flamethrower wires too, and they seemed like they might be long enough, but it would be really close.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! Last edited by BossHogg69; 11-04-2016 at 05:18 PM. |
11-04-2016, 06:53 PM | #17 |
My 72 GMC 350 ZZ4.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
11-04-2016, 07:32 PM | #18 |
Here's my setup I used to have them hidden under the manifolds but I burnt some wires and it was impossible to work on so this was the solution
My Patinia'd 69 69-http://67-72chevytrucks.com/vboard/showthread.php?t=517537 My RHD 68 http://67-72chevytrucks.com/vboard/s...d.php?t=594928 |
11-04-2016, 08:21 PM | #19 |
I like these, can you provide some info on them? My HEI wires are very long and the stock looms don't do a good job of containing them in an orderly fashion.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear Last edited by 70STOVEBOLT; 11-19-2016 at 08:48 PM. |
