Old 09-30-2010, 06:57 PM   #1
djimenzj
3 Birds 1 Stone, body work, Vin Desipher and and drop spindles...
Name:  CAB FLOOR.jpg
Size:  41.1 KBOk guys thanks for the help in advance ! ! !
How is my body work going ? Should I take it down more or woill this give me a quality foundation for a ok paint job ?
Is my truck a original short bed ? The sticker in the glove box does not match my Vin palate and that scares me !
Are these drop spindles ? Got the whole cross memeber for $200 bucks, ohh I even got a prop valve...
djimenzj is offline   Reply With Quote
Old 09-30-2010, 09:19 PM   #2
evilways
evilways's Avatar
Re: 3 Birds 1 Stone, body work, Vin Desipher and and drop spindles...
C=Chassis, 4x2
E=Engine type, V8
1=GVW range, 1/2ton
34=Model code, Fleetside pickup
Z=Assembly plant, Fremont
Z=Year, 1970
51521= Serial number
Thats what I found.
As far as the glove box goes, that could have been replaced by the PO from a different truck, for that matter you could have a totally different cab on the frame from original. Do you have a title that matches anything on the truck?
Mark
1967 C/10 stepside lwb daily driver
1968 C/10 fleetside lwb parts truck
1971 Cheyenne Super swb project
evilways is offline   Reply With Quote
Old 09-30-2010, 09:26 PM   #3
djimenzj
Whats up Evil Ways... The title matches the cabs vin number. The title says pickup, so I guess the vin doesnt tell you if it's a short bed or not... Thank Evil Ways...
Old 09-30-2010, 10:34 PM   #4
OARNGESI
OARNGESI's Avatar
From the back they dont look like drop spindles
check the frame on the driverside front there willl be a partial vin to see if the frame matches the vin, have you looked at the frame rails to see if it was cut down
the paint looks fine from here but usually you want origional paint and 1 repaint you should be good if its been repainted 2 or 3 times you may want to take it all the way down
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 10-01-2010, 11:21 AM   #5
chevy_mike
Never Ending Projects
chevy_mike's Avatar
No, those are not dropped spindles. They are stock as the spindle is near the bottom. Dropped spindles, the spindle center is about the middle between the upper and lower mounts.
Here are CPP modular dropped spindles to give you an idea.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 10-01-2010, 01:14 PM   #6
djimenzj
OARNGESI, its og paint on the inside and one repaint in the outside, I don't see where it's been cut, where do they cut the frame when making a shot bed ? middle back ?
CHEVY_MIKE, THANKS FOR CONFIRMING... Ohh well is 200 still a good deal ? I got newer or rebuilt calipers, prop valve, newer ball joints and some lines...
Thanks guys !
Old 10-02-2010, 12:20 AM   #7
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
Thanks guys !
$200 seems like a good price to me. I'm in the process of rebuilding/converting my 69 to 71-72 front end parts. The upper ball joints alone cost me more then that. I'd say you made off pretty good on that deal. That's just my opinion though.
Matt
'69 Chevy SWB Fleet, Primer Black; Project No Name
'06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold
'08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!!
'99 Dodge Dakota R/T, Intense Blue; DD, Sold
Originally Posted by longbed67 View Post
The tig welds are not the prettiest i have seen but they do have good penetration.
Originally Posted by oldblue1968chevy View Post
There are two things in life where penetration is really important.....and one of them is welding.
stealthy '69 is offline   Reply With Quote
Old 10-02-2010, 02:51 AM   #8
OARNGESI
OARNGESI's Avatar
oarngesi, its og paint on the inside and one repaint in the outside, i don't see where it's been cut, where do they cut the frame when making a shot bed ? Middle back ?
look under the cab if you dont see any evvidence you should be good as far as the paint unless it seems super thick it should be more than fine
70 SWB STEPSIDE
70 BLAZER
09 challenger
