Old 09-30-2010, 08:56 PM   #1
nachodog2
Hell yeah!!!
nachodog2's Avatar
Rearends
Does anyone know how much narrower an s10 rearend is as compared to a stock 64 rearend?
Stock is good but custom is the sh*t!
nachodog2 is offline   Reply With Quote
Old 09-30-2010, 10:59 PM   #2
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: Rearends
I know that a S-10 rear is 54.5" outside drum to drum. I have one in my shop.
Hope that helps some.
Tony
Tony
66 GMC LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=399283
AZ66GMC is offline   Reply With Quote
Old 09-30-2010, 11:18 PM   #3
nachodog2
Hell yeah!!!
nachodog2's Avatar
Re: Rearends
Thanks AZ. You've chimed in a few times on my threads and your responses are always helpful.
Old 09-30-2010, 11:29 PM   #4
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: Rearends
No problem.
One thing to consider is that the s10 has metric brake lines an you would need to get a $2 adaptor at the auto parts store to connect the older standard line to the s10 T fitting. You can make the E-brake cable work too, if I remember correctly, you just need to drill out the backing plate hole a little larger.
I had a friend that put a s10 rear in a 59 apache about 10years ago. He also put the front suspension on it too. It rode pretty good and sat pretty close to the ground in stock form.
Tony
Tony
66 GMC LWB
Old 09-30-2010, 11:44 PM   #5
bubba327
HOW long until spring??
bubba327's Avatar
Re: Rearends
Let me know how that works if you do change it out.. I"ll be interested in the results
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 09-30-2010, 11:52 PM   #6
Captainfab
60-66 Nut
Re: Rearends
For reference the '63 to early '70 rear ends measure 62" WMS to WMS
Old 10-01-2010, 12:32 AM   #7
raycow
Re: Rearends
That 54" dimension is for a 2WD S-10. The 4WD rears are a few inches wider, maybe about 58". Most people putting S-10 frames under earlier trucks like AD usually go with the 4WD rear and still get the deep wheel look.
Ray
raycow is offline   Reply With Quote
