Old 09-30-2010, 10:07 PM   #1
62 Bowtie
62 Bowtie's Avatar
sealant/tape
Just curious as to what youz guys are putting on fittings to make a nice seal I was told to use thread tape and sealer but no specific brand. I'm looking for brand names please thanks, Tony
62 Bowtie is offline   Reply With Quote
Old 09-30-2010, 11:12 PM   #2
swamp rat
swamp rat's Avatar
Re: sealant/tape
Teflon tape is teflon tape, any auto parts store or hardware store carrys it. liquid thread sealer? depends on the application, Permatex has some.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 10-01-2010, 08:41 AM   #3
Shane
Shane's Avatar
Re: sealant/tape
teflon tape is not a sealant ... it is a lubricant.
it allows the threads to tightened more in order to make more uniform contact between the thread faces which in turn makes the seal.
Shane is offline   Reply With Quote
Old 10-01-2010, 09:14 AM   #4
Rochlow
Re: sealant/tape
Loc-tite makes a thread sealant. It's in a red bottle. Just don't use the thread locker.
http://www.*****************/catalog/...thread-sealant
Rochlow is offline   Reply With Quote
Old 10-01-2010, 07:06 PM   #5
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: sealant/tape
loctite 545
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 10-01-2010, 10:48 PM   #6
swamp rat
swamp rat's Avatar
Re: sealant/tape
It also allows the unknowing to overtighten there fittings causing splits cracks and or pulled threads..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 10-02-2010, 09:03 AM   #7
Shane
Shane's Avatar
Re: sealant/tape
been around pneumatic and hydraulic fittings a long long time and can honestly say I've never seen this happen. especially considering pipe threads (NPT) are DESIGNED to deform in order to make a uniform seal.
sounds more like a Sasquatch wanna-be not knowing what he is doing ...
but hey, don't take my word for it ... google it ... let me help.
http://en.wikipedia.org/wiki/Thread_seal_tape
Old 10-03-2010, 09:59 PM   #8
kev2809
low n' slo
kev2809's Avatar
Re: sealant/tape
loctite 545 seals real good. little expensive, but well worth it imo.
plus i always kept screwing up the teflon tape lol
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 10-05-2010, 09:25 PM   #9
GGinferno
DiablosWeldingFabrication
GGinferno's Avatar
Re: sealant/tape
Im using good old teflon tape! Never leave home with out it!
GGinferno is offline   Reply With Quote
Old 10-06-2010, 09:15 PM   #10
texastrendz
Re: sealant/tape
they actually have diffrent grades of telfon tape. i like teflon tape because it can be used in a wet application. i know air lines are not hydraulic lines but loctite would never work in a wet application. i have used teflon tape with great success and will never use anything else. i have heard that the loctite actually dries hard, does vibration on the road cause issue with this?
texastrendz is offline   Reply With Quote
Old 10-06-2010, 09:17 PM   #11
Shane
Shane's Avatar
Re: sealant/tape
loctite 545 works in wet (hydraulic) applications. very well, actually.
loctite hydraulic/pneumatic thread sealant (purple-545) is not the same chemical compound as loctite thread locker (red-271, green-290 or blue-424).
justa fyi.
Old 10-06-2010, 11:08 PM   #12
texastrendz
Re: sealant/tape
justa fyi.
correct you are sir, i left out the important part(dam). in the field is the condition i am talking about. it has a cure time where tape does not. sorry i forgot to state that. i have had nothing but bad luck with anaerobic sealants. maybe not enough patience.
