Old 09-30-2010, 11:03 PM   #1
blklblsk8tr13
blklblsk8tr13's Avatar
d44 front axle bearings replacement?
how would i go about changing axle bearings at the ends of the shafts on my dana 44 front? it has disc brakes.
blklblsk8tr13 is offline   Reply With Quote
Old 09-30-2010, 11:44 PM   #2
ERASER5
ERASER5's Avatar
Re: d44 front axle bearings replacement?
Remove the hub lock assembly, the brakes, drum or rotor, remove the hub nuts, put board on the hub and smack the board with big hammer. One there is a little separation, use a small pry bar and work around the hub until it is free.
To remove the bearing, try a bearing puller. I could not find one that would work for mine, so I noticed my small pry bar, the kind that is like a screw driver that is bent at the end. Reaching down the hub tube, I was able to contact the bearing in 2 spots. A little hammer tap, not hard at all, all the way around and pop goes the weasel. I had to buff out some scratches, but way better than the grinder marks the last idiot left. Used a socket to press the new bearing home.
That's how I did mine 2 weeks ago.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 10-01-2010, 12:00 AM   #3
blklblsk8tr13
thanks. but are we talking bout the bearing in the axle housing? im talking about number 16 or 17 in this pic. the ends of my shafts are wobbling around in the tube and in the hub.
Old 10-01-2010, 12:55 AM   #4
ERASER5
ERASER5's Avatar
You said front, and ends. I presumed you were talking about the hubs at the end of the axle in the front. The picture you show is a rear diff and ends are different.
I only did my ball joins, hubs, and wheel bearings. The hub is the outer end, part 16 and 17 and inside the diff. For those the carrier has to come out I believe.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 10-01-2010, 05:58 AM   #5
LONGHAIR
That is the outer bearing, it is pressed onto the end of the axle....but once again, that is a rear axle. They are different, from the front.
The inner axle bearing (in both front and rear) is actually the carrier bearing. You cannot simply replace them though. That requires serious internal work, which requires a professional. If not set-up properly, the ring and pinion will fail... quickly.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 10-01-2010, 11:38 AM   #6
Schralper
Schralper's Avatar
front bearings use a brass drift
do you mean the needle bearings in the roller or the tapered wheel bearing races?
either or the brass punch is the way to get'em out w/o wreckin the rest
Schralper is offline   Reply With Quote
Old 10-02-2010, 01:16 AM   #7
swamp rat
swamp rat's Avatar
http://128.83.80.200/taco/axle.html
This help??
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 10-02-2010, 06:46 AM   #8
LONGHAIR
I love that guy's description of how to get the spindle off..."It might take some rubber-mallet persuasion"
Yeah, good luck with that.
Old 10-02-2010, 11:03 AM   #9
swamp rat
swamp rat's Avatar
Rubber mallett? Chisel and a 4 lb sledge maybe??
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 10-02-2010, 09:31 PM   #10
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Yeah my spindles were a B***H to bet off!
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 10-03-2010, 08:44 AM   #11
LONGHAIR
There is a nifty little tool to make this much easier. It screws onto a slide hammer and pulls it off.
Old 10-03-2010, 02:13 PM   #12
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Yep I almost rented one of those but I finally got it.
Tony
