Old 10-01-2010, 02:37 AM   #1
roofingbloke
Lowering front bumper
I am going to lower my front bumper so the top edge of the bumper looks in thine with the rounded body panel under the grill,
Q. has anyone done this also.
roofingbloke is offline   Reply With Quote
Old 10-01-2010, 11:10 AM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Lowering front bumper
I've done this on other vehicles (not a mid-year truck). What I've done in the past was weld up the existing carriage bolt holes, and then mock up the bumper where I wanted to re-position it. I would then mark where the new mount holes will need to be punched or drilled. Sounds like a neat idea. Good luck.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 10-01-2010, 11:39 AM   #3
erock805
erock805's Avatar
I like the idea too. the front bumper sits higher than the rest of the truck for sure. also the fronts always look pretty busy or crammed together...making it a bit taller should help that.
"Do what you want to the girl, but leave me alone!"
erock805 is offline   Reply With Quote
Old 10-01-2010, 12:52 PM   #4
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Anyone have pics of what this looks like when done?
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 10-01-2010, 03:46 PM   #5
roofingbloke
I think about 1 and a quater inch, would do it, a z cut in the ver tip af the chassis,
Old 10-01-2010, 07:14 PM   #6
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
the front frame horns conform to the shape of the bumper, so I would suspect that the thing to do would be is just slice them off, leave 'em bolted to the bumper, drop the bumper, and weld 'em back where the new location is.
after that then pull the bumper, and weld in some gussets.
Old 10-01-2010, 10:48 PM   #7
HSkinner
post pics when ur done
HSkinner is offline   Reply With Quote
Old 10-01-2010, 11:58 PM   #8
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Neat idea, would like to see the in progress as well as the finished pics if possible.
fryer1979 is offline   Reply With Quote
Old 10-02-2010, 12:38 AM   #9
Captainfab
60-66 Nut
This is exactly how I would do this. The bumper could also be moved closer to the grill panel at the same time
I agree we need to see some pics of this mod.
Old 10-02-2010, 10:14 AM   #10
lakeroadster
While I understand that lowering the front bumper would look better as viewed directly from the front of the truck I believe this will not look better from the side. In the stock configuration the bottom of the front bumper is already a bit lower than the lower front fender. Dropping it further will make the "flow" look strange....IMHO. Kind of like a snow plow.
Tucking the bumper closer to the body would look better... my bumper is bent and is closer on the passenger side than the drivers side. Visually the bent side looks better than the stock side! Perhaps I should driver into something on the drivers side! The Larry, Daryl and Daryl Custom Shop method.
lakeroadster is offline   Reply With Quote
Old 10-02-2010, 11:10 PM   #11
SCOTI
SCOTI's Avatar
I agree. Up & in would 'look' better vs. down. That 'snow-plow' descript seems to fit if just dropping the bumper.
Since my build is on a 68 frame, I wasn't 100% certain where the bumper needed to be w/o swapping the body. So I made front bumper brackets much like rear bumper brackets (instead of the fixed mounting position on the frame horns). This should allow me a little wiggle room to place the bumper in an optimal position vs. the body. Still haven't swapped the body so I don't know how well it's going to work.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-03-2010, 08:37 AM   #12
lakeroadster
Frizzle Fry's Truck
Old 10-03-2010, 08:38 AM   #13
lakeroadster
The only front bumper mod's I can recall is Frizzle Fry's Truck...
Keeping in mind he has done extensive rework of the wheel opening by replacing the stock lip with one from a 67 fender.
Here is a link to his photo's
http://photobucket.com/albums/y236/e...61%20C5%20PU/?
Old 10-05-2010, 06:38 PM   #14
erock805
erock805's Avatar
I still dig it. I think Im gunna pull the trigger on this. Hate how high the bumper sits compared to the rest of the truck. Worse comes to worse a fella could extend the fender in the front down a bit.
Old 10-05-2010, 09:08 PM   #15
Frizzle Fry
Frizzle Fry's Avatar
That's exactly what I did before the section. I like it tucked and moved down a bit. Jury is still out on the section. We'll see how it turns out in 2025
Frizzle Fry is offline   Reply With Quote
Old 10-05-2010, 10:19 PM   #16
ConnDemned
I put a bumper off a 67-72 chevy truck, just hung it on the front frame horns, and thought it looked sway to tall. I believe it was only a couple inches taller but it hung down and looked funny compared to the fenders. I'm going to just flip the front bumper, I have a strong dislike for the stock bumpers and their upside down look.
Frizz, do you have any more pics of the wheel arch swap, or someway I could copy your idea without thinking? Looks great with the "radius" look to them
ConnDemned is offline   Reply With Quote
Old 10-06-2010, 12:01 AM   #17
Frizzle Fry
Don't want to hijack here. Pics are in my PB acct previously linked and some description is in the build thread. PM me if you want more detail.
Old 10-06-2010, 08:20 AM   #18
lakeroadster
I'm going to just flip the front bumper, I have a strong dislike for the stock bumpers and their upside down look. Posted via Mobile Device
I have heard others talk about flipping the front bumper. Anybody got any photos of this?
Old 10-06-2010, 12:20 PM   #19
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I had thought about doing this too. I don't recall where I ran across the pic but I did see one done and wasn't really sure if I liked it. Too bad the bumper mounts to the frame rails and to flip it, it requires much more work then just bolting brackets on upside down.
Curious if anyone still has pics.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 10-06-2010, 02:26 PM   #20
bigdaddy64
bigdaddy64's Avatar
I've always thought that chevy screwed up and put the bumper on upside down! I've got some pictures of a couple of trucks with the bumper flipped at home (at work now), but i'll be flipping mine. Have to cut the frame horns off and flip side to side to do it. Just waiting to get my front wrap back on to do it. imo it looks better flipped.
66 c20 with 1/2 ton 73-87 front and rear suspension
2-1/2" drop spindles, air-bags, c-notch rear frame
463 Pontiac, SRP Pistons, Eagle Crank and Rods
Mega-Squirt Fuel Injection
bigdaddy64 is offline   Reply With Quote
Old 10-06-2010, 04:38 PM   #21
chevy_mike
chevy_mike's Avatar
Cool. Post up some pics.
I have also wondered what a '55 Bel Air bumper would look like. Fill in the apron like the Bel Air too.
Old 10-06-2010, 05:24 PM   #22
Frizzle Fry
Not that it matters, but I think they look dumb flipped. Look at the Belair. Would it look good with the top of the bumper sticking out? Same aesthetic applies to the trucks. That's ok, I'm sure some of the stuff I've done looks weird to some people too.
Old 10-06-2010, 05:46 PM   #23
chevy_mike
chevy_mike's Avatar
I think I recall Foose doing a Bel Air and flipping and trimming the stock bumper and it really looked sweet... but with Foose doing it, it always ends up looking sweet!
Old 10-06-2010, 07:55 PM   #24
ConnDemned
I have a pic I saved to my phone, it is only a side pic, but I can't post it from my phone. I have seen a few where they flipped the bumper but the angle was off so it looked goofy. I have a camaro clip so I have to redo bumper mounts anyway so I will mount the bumper to a correct angle. If I can find a pic I will post it.
This isn't the pic I was thinking of but kt shows it a little better, might wanna zoom in a little as the pic maybe small
