steering column ?
does anybody know the pn for the bearings for the steering column? it is an auto non tilt. i can get them local if i can find the bearing numbers.
Hollister Road Co.
Re: steering column ?
Which bearing, Upper or lower?
i am going to change all of them.
Grandpa in the rustmobile...
Good luck chris! You need it that column felt loose for sure
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Hollister Road Co.
Lower is 3981935
Upper is 5679205 Both available at http://www.gmpartsgiant.com/chevrolet-parts.html so I suspect also from other GM dealers. Check the numbers before you order |
