Old 10-01-2010, 02:34 PM   #1
Frankbrando
looking for 54-59 rear engine crossmember
hi there guys new im a new member from quebec canada, and im looking for a 54-59 chevrolet 235 rear engine crossmember, for a low budjet build im doing, if anybody can help me out it would be much appreciated. The one that came with the truck was hacked up and i don t think i can use it. thanks
Frankbrando is offline   Reply With Quote
Old 10-01-2010, 06:15 PM   #2
raycow
Re: looking for 54-59 rear engine crossmember
The problem with those bellhousing crossmembers is that they usually get destroyed in the process of taking them out.
Yours looks like it night have come out of a later model truck with wider side rail spacing. If it did, that's good. You can cut it to the length you need, weld on end plates, and bolt those to the rails.
Ray
raycow is offline   Reply With Quote
