Old 10-01-2010, 06:57 PM   #1
harrdawg54
harrdawg54's Avatar
Wiper arm removal
OK...first, I read all the posts about getting the arms off using a screw driver, that didn't work. I then bought the wiper arm removal tool from snapon, but I guess I just can't figure out how to use it. It seems pretty simple, but I don't know where to insert it, front or back side, to release the clip, or which end to use. Can anyone help?
1969 Chevy K20 Custom Camper
350, 4sp, 33's
High on plans, Low on funds
harrdawg54 is offline   Reply With Quote
Old 10-01-2010, 08:43 PM   #2
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: Wiper arm removal
Are you trying to take off the entire are down at the stud?
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 10-01-2010, 10:14 PM   #3
Hubscrub
Cruzin
Hubscrub's Avatar
i just poped mine off yesturday, i just take a screwdriver and slide down the little clip and it should work off the shaft if not just use the screw diver the gently push up on them, just lay something on you cowl if you have nice paint
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
