Old 10-02-2010, 01:58 PM   #1
iehotrod
iehotrod's Avatar
Has any changed grills from 62 to a 61 Apache?
Well, I just purchased a 62 C10 Shorty. I really don't like the headlight bezels on the 62's. I prefer all others but 62's. I am thinking about maybe going with an apache grill with dual headlights but I have no idea if it they are interchangeable without having to cut or add any metal. Does anyone know if I have to change anything else other than headlight buckets and grill? Any help would be appreciated. Thanks.
iehotrod is offline   Reply With Quote
Old 10-02-2010, 03:00 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Has any changed grills from 62 to a 61 Apache?
You may need to drill a couple of new mounting holes depending on which configuration you end up with, but if you get the entire 4 headlight grille assembly with the mounting brackets and wire harness it should just bolt on to your radiator support, and the grille harness should plug right into the bulkhead connector on the driver side of the radiator.
The wiring from the dimmer switch to the radiator support is the same for both 2 and 4 headlight grilles, as is the matching connector leading from there to the headlights. After the connector the headlights are wired slightly different depending on if you have 2 or 4, so all you have to do is use the harness that corresponds with the number of headlights.
Old 10-02-2010, 09:00 PM   #3
iehotrod
iehotrod's Avatar
Thanks! Markeb01 I am for sure changing now I just have to find me a complete set up.
Old 10-03-2010, 04:43 AM   #4
62 Longbed
62 Longbed's Avatar
... Will keep my eyes open for a grill around here .... P.S. Congrats on the shortbox 62 !!!
62 Longbed is offline   Reply With Quote
Old 10-16-2010, 01:24 AM   #5
iehotrod
iehotrod's Avatar
Thanks 62 Longbed. Yeah please me let me know if you find an apache grill will with the dual head headlights it would have to be complete with buckets and bezels just so I can do a clean swap with you or anyone who may come across one.
Old 10-16-2010, 04:43 PM   #6
62 Longbed
62 Longbed's Avatar
Not a problem iehotrod ..
I would make sure it was all complete ... Trying to piece together a 62 grille now ... What a pain in the *%*&$&$## .. trying to find all the parts .. Should just stay with the 64 5 6 grill thats in it now ... Still looking .. Good Luck & Thanks !!!
Old 10-18-2010, 01:27 PM   #7
clemdaddy
clemdaddy's Avatar
is this the grill you are looking for? if so there is a salvage yard near me that had one. not chromed but complete with a few dings in it. I think it is a 61 model grill, but not sure.
the one shown I put on a 65 suburban built about 5 years ago and I haven't been back to that yard since. had to drill a couple of holes, thats all. pm me and I will go back and look for it.
clem
clemdaddy is offline   Reply With Quote
Old 05-18-2011, 01:01 AM   #8
iehotrod
iehotrod's Avatar
Man how did I miss this oppertunity. Am I to late to take you up on your offer?
Old 05-18-2011, 11:55 AM   #9
Rogue
Airport Bum
http://sacramento.craigslist.org/pts/2387483494.html
1964 Chevrolet C-10
1941 Chevrolet coupe
1962 Thunderbird
1959 Edsel Villager
1963 Skylark
Rogue is offline   Reply With Quote
Old 05-18-2011, 02:05 PM   #10
62 Longbed
62 Longbed's Avatar
I'm in the process of doing the same thing ... I finally got everything for the 62 grill , didn't like the way it looked ... Got a 1960 grill , being powdercoated , then I'll install .. Bolts up in my 62 with no problems ... Ordered a new wire harness for it ... Excited !!!! Better Looking .... Good Luck !!
Old 05-18-2011, 11:57 PM   #11
iehotrod
iehotrod's Avatar
It sure is. I really need to replace the one on my 62 its bent and I prefer to use a 60-61 grill.
Old 05-19-2011, 08:23 PM   #12
steve'62
steve'62's Avatar
Please note that you must be a supporting member to post classified item. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
steve'62 is offline   Reply With Quote
Old 05-19-2011, 09:21 PM   #13
steve'62
steve'62's Avatar
This does look nice though!
Old 05-19-2011, 10:15 PM   #14
62ShortStep
62ShortStep's Avatar
'62 grill (not mine):
http://cgi.ebay.com/ebaymotors/1962-...Q5fAccessories
62ShortStep is offline   Reply With Quote
Old 05-20-2011, 08:47 PM   #15
62low72High
62low72High's Avatar
Bought my complete grille from Jonzcustomshop. The swap was a piece of cake. Went from 62 to 61 in a afternoon.
62low72High is offline   Reply With Quote
Old 05-20-2011, 11:57 PM   #16
Dino Driver
Dino Driver's Avatar
clem
This is a 1960 grill. The 1961 has "Chevrolet", "floating" in the middle of the grill bars.
Dino Driver is offline   Reply With Quote
Old 05-21-2011, 09:04 AM   #17
defgone
is the 60-61 grill swap just as easy onto a 63?..
i prefer the look of the 4 headlights over the 2 as well...
defgone is offline   Reply With Quote
Old 05-23-2011, 12:55 PM   #18
Dino Driver
I have seen the grill panel sold as 1960-1966 and I have seen it sold as 60-62, 63-66. I think the only difference is along the bottom where there are notches for the frame rails to go through. This does not effect the mounting of the grill though.
The hardest part, aside from taking your old grill off, is to add the wire for the high beams. LMC truck and others have a cool kit out that lights up all 4 lamps when you go to high beam...I have used the kit on all of my previous trucks.
Mike
Old 05-23-2011, 06:56 PM   #19
steve'62
steve'62's Avatar
Old 05-23-2011, 07:58 PM   #20
Dino Driver
Try contacting this guy: http://www.stovebolt.com/RJ/
Helped me find something I had been looking for, for years.
Old 05-23-2011, 10:37 PM   #21
willyp
willyp's Avatar
i just scored this 60 grill off a chimney sweep work truck in a junk yard on saturday.
The price of cool aint cheap.
willyp is offline   Reply With Quote
Old 05-23-2011, 10:45 PM   #22
N2TRUX
Happy to be here
N2TRUX's Avatar
Guys this is NOT the Classified Forum. Offer to buy and sell is against forum rules unless you are a subscribing member. Please keep that in mind or this thread will be closed.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-24-2011, 08:07 AM   #23
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
My 65 had that grill and I really liked it.
Now my 61 Apache and it has a later model C10 hood. I still have the same combo.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 05-24-2011, 04:42 PM   #24
clemdaddy
clemdaddy's Avatar
This is a 1960 grill. The 1961 has "Chevrolet", "floating" in the middle of the grill bars.[/QUOTE]
thanks dude for the heads up... not really sure about those earlier grills.
i do like the dual headlights much better.
scored another "60" grill for my current project.
question??? has anybody tried the spray-on type of chrome plating thats out there? i'm curious about quality and cost differences.
Old 05-24-2011, 07:23 PM   #25
steve'62
steve'62's Avatar
Nice score willy
grills
