Water Pump ?
Was planning on going up to Summit this weekend and get the GM Performance 12497697 serpentine conversion kit. Read a bunch on this and getting a little confused on the reverse rotation water pump. This kit says it come with a long reverse rotation water pump. Do I need to buy a different water pump or will that one work for my 86 C-15 with a 350 conversion? Thanks for the help
Re: Water Pump ?
The way the serpintine setup is made, it turns the water pump backwards from a v-belt setup. The water pump in the kit will work on your engine. it bolts right up only the impeller blades are made to be spun the opposite way.
| Bookmarks |
