Old 10-02-2010, 04:46 PM   #1
kcfirstbuild
Hastings Piston rings
So i purchased a set of over sized piston rings from Hastings. Was in the process of installing the very last top compression ring on the piston when it snapped in half.. I applied no more pressure then the other rings that I had finished minutes before. So is there a warranty for crap like that or do i have to buy a new set of just one ring. It seems like when i take one step forward it end up taking two steps backwards. New rings shouldn't break, old ones i can see but new ????
kcfirstbuild is offline   Reply With Quote
Old 10-02-2010, 04:54 PM   #2
Kerry P
Re: Hastings Piston rings
I'd contact Hastings directly. With or without warranty I thing they may handle it under "good will" since the cost to them for one ring will be small.
A lot of companies out there are total jerks about stuff like this but some are OK. Two of the best with customer support I've worked with are ARP and Edelbrock. I hope Hastings gets added to the good list.
Good Luck
Kerry P
Kerry P is offline   Reply With Quote
Old 10-03-2010, 12:09 AM   #3
llowlife
I'm sitting on a complete set minus 1 ring for something similar. They were sealed power plasma 1/16th however.
In the beginning of a change, the patriot is a scarce man, brave hated and scorned. When his cause succeeds however, the timid join him , for then it costs nothing to be a patriot.
I am a revolutionary...so my son can be a farmer...so his son can be a poet. If there must be trouble, let it be in my day, so my child may have peace...
72 short step w/ 388 /4l80e/ and 3.08 gears.
llowlife is offline   Reply With Quote
Old 10-03-2010, 08:47 AM   #4
71 super
71 super's Avatar
I broke one several years ago from hastings and I had to buy a replacement, but it was much cheaper than buying a whole set. Unless they have changed you should still be able to do this.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 10-03-2010, 09:41 AM   #5
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
compression ring's are made to be HARD so they will wear well but they are BRITTLE and will break easy ,
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
