10-03-2010, 07:57 AM | #1 |
wheels
I've looked around and noticed it's quite hard to find aftermarket wheels for the 6 lug pattern on our trucks. Appears due to the fact that the center hole in the wheels we have is larger than most, so even though the wheel lug pattern may be OK, the center hole of most types wont go over the hub center. A guy was telling me that adapater plates are available that move the wheel out enough to not interfere with the part that would stick through the wheel and therefore one could use newer GM wheels or basically anything that had the same 6 lug pattern. Does anyone utilize these or have and info on them?
10-03-2010, 09:02 AM | #2 |
Re: wheels
Here is a link.... http://adaptitusa.com/6-lugto5-lugadapters.aspx?page=3
The pictures don't match the descriptions though...... and I don't know of anybody who has used these, so I can't vouche for 'em. Last edited by lakeroadster; 10-03-2010 at 09:09 AM. |
10-03-2010, 03:28 PM | #3 | |
Re: wheels
The spacer shims the wheel out enough so that the offending material doesn't contact the hub flange. The problem w/spacers is it puts more stress on the already 'weak' link.... the OE 7/16" studs. Spacers are commonly made from cast aluminum & prone to cracking w/age (many heat cycles). Adapters also move the wheel out but they do it differently. The adapter itself bolts to the OE hub just like a wheel. The new wheel then bolts to different studs on the adapter. Adapter studs are usually 1/2" studs & adapters are made of billet aluminum (not prone to cracking ). The problem w/adapters is they increase the track width by 1" minimum. This may (or may not) be an issue depending on what the backspacing (offset for late model wheels) is.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-03-2010 at 03:29 PM. |
10-03-2010, 04:29 PM | #4 |
Re: wheels
I can't recommend the use of "ET" style lug nuts enough on our trucks with the aforementioned weak 7/16" studs.
http://www.cwausa.com/ETLUGNUTS.html |
10-03-2010, 05:30 PM | #5 |
Re: wheels
Check out wheel vintiques. They have 'em. I bought mine from Summit which has free shipping.
10-03-2010, 07:51 PM | #6 |
Re: wheels
Yes, I think the 1/4" spacers will give me all the clearance i need. I will measure and check. I believe the original studs will be ok. They all stick past the nut for over 1/4 inch, so should work fine and they are all new. Wish i'd known about these before, i've passed up many good wheel deals because i didn't think any newer wheels would work. Thanks guys.
10-03-2010, 10:54 PM | #7 |
Re: wheels
Lug nut thread engagement should be at least equal to the diameter of the stud in question.
1/4" of thread engagement is nowhere near enough! Using the "et" lugs helps overcome the problem with short studs / thick wheel flanges. |
10-04-2010, 12:05 AM | #8 |
Resistance is Futile
Re: wheels
Skysoldier.......I'm running wheels on my P/U that were originally for 88-98 3/4 ton trucks (6-lug). The front fit no problem as I had done a disc upgrade but the rear didnt fit due to the axle flange. I used the 1/4'' spacer to provide clearance and also used lug nuts with a 60* conical seat and a shank to further engage the studs.
The backspacing on the newer wheels is deep enough that one could use a 1'' billet spacer as SCOTI describes to set the backspacing 'correctly'...matter of opinion, I suppose.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
05-16-2011, 04:01 PM | #9 |
Re: wheels
This thread is worthless without pictures.............glad I finally got to say that....
05-16-2011, 04:15 PM | #10 |
Re: wheels
Someone on here said in the past that the wheels on our truck were "hubcentric" meaning that the wheel is centered on the hub, not the lugs and that would mean that if the hub was not used to center the wheel, just having it close enough to screw the lugs on would not be centered well enough for highway speeds. I hope someone who knows will get in on this, i would like to know. It is true that you can use the lug nuts that cover and take advantage of the whole stud and make it secure enough, just is it centered well enough is the question without the hub center being in the wheel to provide true center?
05-16-2011, 04:50 PM | #11 |
Re: wheels
man i just ordered some wheel vintiques for my 6 lug, i hope they dont have a problem. i dont like the idea of using spacers on wheels. i never have but i would rather not.
05-16-2011, 07:05 PM | #12 |
Re: wheels
I agree, that shoulder of the hub sticking through the hole in the wheel (I think) not only perfectly centers the wheel, but provides support. I have heard guys talk about having accidents because of loosing a wheel when using spacers and shearing the lugs. No first hand experience, but have heard that. Still want to hear from those who know more about this though.
05-16-2011, 08:41 PM | #13 |
Re: wheels
I don't know of a single aftermarket wheel mfg that doesn't make their 6 lug wheels with a big enough hole to clear the hub.
Talking about standard offset aluminum wheels mind you. |
05-17-2011, 02:20 PM | #14 | |
Re: wheels
Posted via Mobile Device Last edited by Brandonc20; 05-17-2011 at 02:21 PM. |
05-17-2011, 02:38 PM | #15 |
Re: wheels
Sorry Harley, but I've tried several aluminum wheels on my truck and have found several with center holes that are 3.25 instead of the needed 3.50. I don't know what brands they were but they are out there and they won't fit our trucks.
Also ran into a set of aluminum slots recently at a swap meet with the six lug pattern and they also were 3.25 and wouldn't fit. |
05-18-2011, 12:16 AM | #16 |
60-66 Nut
Re: wheels
If you find a set of wheels you really like but the center hole is too small, I would check into having either the wheel center holes machined larger, or your hubs turned down. Then compare that cost with what a set of spacers cost.
05-18-2011, 12:28 AM | #17 |
Re: wheels
Look what found here in cali 10 minutes from house have of what most places charge and they air craft material.
http://inlandempire.craigslist.org/pts/2371530383.html |
05-18-2011, 12:29 AM | #18 |
Re: wheels
Reply to: sale-cqgta-2371530383@craigslist.org [Errors when replying to ads?]
-------------------------------------------------------------------------------- Wheel Adapters or Wheel Spacers We Machine Any Size or Lug Pattern Have a Set of 6 Lug Rims you really want to Put on you 5 Lug Vehicle, We Make Custom 2 Piece Wheel Adaptors For any Lug to Lug Conversion. These Spacers/Adapters are made with High Quality 6061-t6 Air Craft Grade Aluminum Studs are High Quality 10.9 Grade Sizes Range From ¼” to 4” WE Ship to the Lower 48 States Need Those Spacers/Adapters Today .. Ask about Our Rush Service Ace Motorsports 909-981-3860 779 N Benson Ave Upland, CA 91786 |
05-18-2011, 02:21 AM | #19 |
Re: wheels
Ask them for a copy of a general liability insurance policy covering their spacers. LOL
