Old 10-03-2010, 12:26 PM   #1
Savage
Savage's Avatar
Running out of gas unpredictably... normal?
Sometimes my gauge will go as far as right on the line for E before the truck begins to stall. However sometimes it's closer to a quarter tank when it starts being completely stubborn. Is this normal for our trucks? Are they simply not that accurate?
Also when I fill up the gauge will read well above F. It will stay there for a while. But once it starts to move I know I'm getting low on gas because once it "breaks free" it goes down pretty damn quick. Is this normal too?
United States Marine Corps
1986 USMC CUCV M1008 (daily driver) / 1984 Chevy K10 RCLB
Savage is offline   Reply With Quote
Old 10-03-2010, 12:53 PM   #2
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: Running out of gas unpredictably... normal?
No, it is not normal. Sounds like you need to drop the tank and have a looksie.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 10-03-2010, 01:06 PM   #3
camshaftgsxr
camshaftgsxr's Avatar
you could also check the gauge itself the three prongs that it makes contact to make be loose or broken and it may not be contacting right, i know i had to put a washer into my gauge cluster in order to make my gauge read correctly
camshaftgsxr is offline   Reply With Quote
Old 10-03-2010, 02:16 PM   #4
PRattenbury
Mine doesn't run out of gas on me because it never gets below an 1/8th of a tank. But it does read way above full when I fill it, and stays there quite a while before dropping like a rock.
PRattenbury is offline   Reply With Quote
Old 10-03-2010, 03:07 PM   #5
camshaftgsxr
check your gauge contacts you may be able to shim it and bring that needle down a bit
Old 10-04-2010, 04:24 PM   #6
primrrd
primrrd's Avatar
mine is not as drastic as above described, but it does ride on full for a long time then it sucks it up. doesnt matter which tank, which makes me think:
it probably aint the sending unit....
- can you further elaborate on how to shim the contacts, or using the washer?
primrrd is offline   Reply With Quote
Old 10-04-2010, 04:28 PM   #7
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
mine did that until i cleaned the ground on both tanks and its been alot better although E means dead empty there isnt any further south than that
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 10-04-2010, 05:06 PM   #8
Number21
Number21's Avatar
After having four of these trucks with 8 tanks total I have yet to find a working gas gauge. The one in my '73 moves back and fourth when I'm stopped on a level surface.
Number21 is offline   Reply With Quote
