10-03-2010, 01:31 PM | #1 |
Aluminum differetial covers ?
I'm considering buying a Strange or JPW heavy duty aluminum rear end cover. Are they worth the money? Will they clear a ECE super track bar? TIA.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
10-03-2010, 01:53 PM | #2 |
Re: Aluminum differetial covers ?
subscribing with interest in the responses
10-03-2010, 08:34 PM | #3 |
Yes, they're worth having. Running w/o one cost me a ring & pinion set. IDK about the ECE bar, but an LPW cover will clear the factory track bar w/o any problems. They're definitely a wise investment.
Chris 1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas 7.02 @ 95.8, 1.45 60' 1965 Chevy C10 LWB, 355 sbc, TH350, daily driver |
10-04-2010, 12:01 PM | #4 |
worth it. look at the lpw covers for a backbrace, even if you don't buy the backbrace kit it will have the mounting holes for it if you ever decide you need it. first one i bought didn't have it and after bending the housing i had to replace the cover to use a backbrace. Dev.
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112 67 nova numbers matching 327 4 speed 13.6 @ 102mph 70 longhorn c-30 402/4 speed 70 c-10 swb 402, muncie 4 speed 94 s-10 350/th350 3:73 posi 71 c-20 402/th400 towrig for racetruck. 72 4wd lifted on 35's 72 350/3 speed winter beater |
10-04-2010, 01:39 PM | #5 | ||
http://www.summitracing.com/parts/STR-R-5221/
10-04-2010, 03:32 PM | #6 |
TA Performance makes a low profile design. Which I think TAP makes them all for all the companies, they just have a different logo machined on the face.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
10-04-2010, 06:00 PM | #7 | |
10-04-2010, 06:12 PM | #8 |
I guess i need to invest in one of these also
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
10-04-2010, 08:45 PM | #9 | ||
I just ordered one, .
10-05-2010, 12:43 PM | #10 |
Based on the times in your sig, I'd say yes, it'd be a good idea.
10-05-2010, 12:50 PM | #11 |
I don't have the brace on mine. Check out LPW's site. They have some install pics in there. The site address is lpwracing.com.
10-05-2010, 01:39 PM | #12 |
Re: Aluminum differential covers ?
Some good pictures on the website. I wonder if you could get away with bolting it to the axle saddles instead of welding brackets on the axle tubes?
10-05-2010, 11:13 PM | #13 |
60-66 Nut
For the brace to effectively do it's job, I would say it should be attached to tabs welded directly to the axle tube.
10-06-2010, 07:23 AM | #14 | ||
R/
10-07-2010, 09:48 AM | #15 |
The cover should be here today. I'm getting worried that my super track bar is going to have interference problems.....
10-07-2010, 09:20 PM | #16 |
Got the cover today and it's a really nice piece, however........the ECE track bar mount on the trailing arm puts the track bar in a position that causes intereference, . I think I have a couple of possible solutions. I'll post them when I get it figured out. Here's some pictures. Always something.....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 10-07-2010 at 09:21 PM. |
10-07-2010, 09:25 PM | #17 |
time for a watts link.
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
10-07-2010, 10:23 PM | #18 |
Naaahhhh, I have a simpler solution than that, .
10-07-2010, 11:26 PM | #19 |
60-66 Nut
Do you know anyone with a tube bender? Could bend an offset in that pandard bar..........
10-08-2010, 08:41 AM | #20 |
I do, but that would defeat the purpose of the double adjustable pan hard bar, not that it needs to be changed that often.
10-16-2010, 09:53 PM | #21 |
I have the same problem with my cover from DTS. Let me know when you have yours figured out. I have yet to address mine. All work and no play these days, which needs to change soon. John
10-17-2010, 07:49 PM | #22 |
Mean Green
Here is my Lpw cover with CCP's deluxe Pan-Hard bar.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel. 60'-1.38 1/4-10.43 MPH-124.6 New ET current 4/2019 AKA MEAN GREEN. Last edited by 68 C-10 KID; 10-17-2010 at 07:51 PM. Reason: Wrong call out |
10-18-2010, 10:34 AM | #23 | |
Thanks for the pic. Do you think the rear sway bar helps much?
10-18-2010, 08:36 PM | #24 |
Mean Green
It drives great. I dial in all four shocks and head to the country back roads. I put in on because I don't have the fabrication tools to make a anti roll bar set up. I was told the Anti-sway bar should help the truck plant its foot print more square on the launch. Also I think I noticed the spool feeling more aggressive on the tire on sharp turns, or I could be smoking something.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel. 60'-1.38 1/4-10.43 MPH-124.6 New ET current 4/2019 AKA MEAN GREEN. |
10-18-2010, 09:29 PM | #25 |
I bought the TA rear end cover and it hit my ECE track bar. I had to send it back for refund. Hopfully Hotrod can come up with a solution.
71 Chevy Stepside 377/350 |
