10-03-2010, 03:29 PM | #1 |
3 on the tree to an automatic?
I would like to convert my 3 on the tree to an automatic shifter. I would like to keep my column and would rather not bore a hole through the floor and put a lokar in it. So is it possible? or do I start cutting.
This statement was made possible by a grant from this station and continued support from viewers like you. Flickr |
10-03-2010, 03:34 PM | #2 | |
Re: 3 on the tree to an automatic?
I'm not sure how well it worked for him.....
10-03-2010, 05:37 PM | #3 |
just get an auto column
ron |
10-03-2010, 05:40 PM | #4 |
cant find one reasonably. (admins this is not a classified ad)
10-03-2010, 05:43 PM | #5 |
Here steal my idea, works great.
http://67-72chevytrucks.com/vboard/s...=409449&page=6 |
10-03-2010, 05:49 PM | #6 |
Delmo- That is AWESOME man what a GREAT idea. What did you end up doing about the E-brake though?
10-03-2010, 06:58 PM | #7 |
It's an auto dude, who needs an ebrake? LOL Besides it sits on the frame.
I ordered a cable from Summit ( 4 foot I think) and a bracket kit for the trans. Used a factory hole in the lever and in the column bracket. Just needed to use a little angle bracket for the cable housing. Easypeezy. |
10-03-2010, 07:15 PM | #8 |
Malibob,
Couldn't you use the Morse Cable concept, but simply mount it such that it has a knob instead of using the e-brake handle? Should work, don't ya think? Last edited by lakeroadster; 10-03-2010 at 07:18 PM. |
10-03-2010, 07:27 PM | #9 | |
1961 crewcab
(pic on post #57 page 3 of the 60 build in that link \/ )
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 Last edited by jonzcustomshop; 10-03-2010 at 07:30 PM. |
10-03-2010, 07:38 PM | #10 |
Ya I've converted a 3OTT using a cable as well. Just a simple bracket mounted to the firewall to hold the cable housing and connected to the first gear lever.
10-03-2010, 07:53 PM | #11 | |
How about this?Malibob, Some links to look at for ideas: Last edited by lakeroadster; 10-03-2010 at 08:08 PM. |
10-04-2010, 06:50 AM | #12 |
Getting excited with all of these ideas. Thanks a ton for the input fellas. I am thinking that maybe some sort of bracket could be attached to the column as a park lock out- something that will move when the shift lever is pulled forward. I have to get into the column a little to see how it all works and maybe come up with something.
10-04-2010, 08:23 AM | #13 |
1961 crewcab
good! then I will copy you!
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
