Old 10-03-2010, 04:15 PM   #1
56ClassicTruck
guys with ac in their trucks
Looking to put ac in my 56 truck if any one has done it what ac unit did you us? Dose any one have pic,s of the inside of the dash how far out dose it stick out? How far down? Any pic,s would help please i am stomped on what way to go.
1996 Dodge 3500 4x4
1977 F250 Camper specal 4x4
1956 Chevy 3100 truck
56ClassicTruck is offline   Reply With Quote
Old 10-03-2010, 05:17 PM   #2
Wrenchbender Ret
Re: guys with ac in their trucks
I put a Vintage-air compact III in my 70. It is a universal model. I should have used the custom one which is available for that model & yours also. It works good & doesn't hang down too far but I have no glove box anymore & the back of the dash is full of tubes for the A/C outlets & defroster, but you will have that with any. Under hood is real clean as none of the heater is protruding from the fire wall.
Wrenchbender Ret is offline   Reply With Quote
Old 10-03-2010, 05:23 PM   #3
solidaxel
solidaxel's Avatar
Under dash Vintage Air and heat
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 10-03-2010, 05:39 PM   #4
56ClassicTruck
Hey cool do have any pic of it installed
1996 Dodge 3500 4x4
Old 10-03-2010, 05:45 PM   #5
56ClassicTruck
Hey solidaxel. Thanks for the pic,s do you have any taken further back so i can see top of dash and floor?
1996 Dodge 3500 4x4
Old 10-06-2010, 02:15 PM   #6
56ClassicTruck
Thanks guys for your replies, i thought more guys installed ac? Maybe not i it takes alway from the interior but i real want ac. I am going to install my 94 buickroadmaster ac unit its big but i have it all wire harness an all for easy plug in. Thanks again guys.
1996 Dodge 3500 4x4
Old 10-07-2010, 03:32 PM   #7
robnolimit
robnolimit's Avatar
We have been a vintage Air dealer for 20 yrs and like them very much. I have installed other brands, and have had some difficulty. The V.A. kit is worth the extra $$. "sure-fit" style kits are easier to install, but don't look as custom. The Gen III Compac is my favorite for the 55-59. We - No Limit - make an underdash apron that is molded to fit the contour of the dash, and provide a nice mounting area for the vents and controls.
robnolimit is offline   Reply With Quote
Old 10-07-2010, 04:26 PM   #8
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Hey Rob, do you have a part number or a pic of the underdash apron? I still far way from do AC but would like to know it is.
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 10-07-2010, 05:01 PM   #9
1952ssr
1952ssr's Avatar
I plan to use Southern Air Superfrost by Southern Rods, very good prices and systems look top notch. Google them and check their site out.
1952ssr is offline   Reply With Quote
Old 10-25-2010, 04:06 PM   #10
56ClassicTruck
Do you have info on that gen3 i only see the gen2. Do you sell the ac unit vent and control? Or do you have buy the hole kit?
1996 Dodge 3500 4x4
Old 10-25-2010, 04:18 PM   #11
56ClassicTruck
hey joey i looked at there maxi 1 they said it will work for me with my lt1 parts.
1996 Dodge 3500 4x4
Old 10-25-2010, 04:47 PM   #12
1952ssr
1952ssr's Avatar
Yeah, that's the way I'm going. They gave me a price of 271.00 using my compressor, not to bad.
Old 10-25-2010, 04:53 PM   #13
56ClassicTruck
man they told me$600? What did you get with just the under dash unit buy it self?
1996 Dodge 3500 4x4
Old 10-25-2010, 05:01 PM   #14
Wrenchbender Ret
I'll get some photo's tomorrow. Robno's post makes me feel a lot better. He say's the Gen 3 is the way to go. I used a factory A-6 comp. & a cond. from a small car. It works real good. I'd like to have more fan speeds.
Old 10-25-2010, 05:43 PM   #15
56ClassicTruck
Would like to see your pictures. What car did you use. I was going to use my 1994 buick roadmaster for i am using the motor and harness an all but ac unit is way to BIG bummed. I was also thinking of a2003 s10 ac unit i can get one for$150 with the controls just don’t no how big it is? And it would work with my lt1 compressor and rest of my parts.
1996 Dodge 3500 4x4
Old 10-26-2010, 10:27 AM   #16
1952ssr
1952ssr's Avatar
I'm going with the Superfrost kit $300 cheaper that the Maxi1, that's the differance.
I'm getting the unit $200; condensor $92; and dryer $79.
Old 10-26-2010, 01:57 PM   #17
OrrieG
OrrieG's Avatar
I am putting in Vintage Air sure fit for the TF. Here are two trial fit photos to show how far it hangs down and intrudes into the glove box. I just got the under dash unit, I am going to buy a Sanderson compressor and condenser. I am still working on how to run the lines. You can see in the one photo where I marked where VA wants you to run the lines. I am going to get them tucked up higher and into the fender side of the inner fender panel. I am also looking at a different way to run and mount the outlet grilles.
OrrieG is offline   Reply With Quote
Old 10-26-2010, 03:11 PM   #18
56ClassicTruck
Hey OrrieG, that looks grate good luck figuring it out buy the work you have done i sure you will. On my trcuk i was going throw the firewall its not going to be a show truck but my every day driver i want to drive it every were. Wish i had the money to built one:-(. That's way i been looking for my cheapest way on this project its or first not a cheap hobby lol i am sure you all no that.......thanks for the pic, s
1996 Dodge 3500 4x4
