Old 10-03-2010, 04:34 PM   #1
cam.man67
cam.man67's Avatar
frame rust!
Just got under my truck to check out what I need when I get around to replacing the trailing arms, and I found out the frame area where the spring and clamp attach to is rusted through on the right side.
My thinking is, first, does anybody sell frame pieces that can be welded in? If not, can I just take a piece of 1/4" steel under there and weld up the frame?
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy"
1996 Gmc 1500 Z71, 350, 4l60e, 3.73s
1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s
1989 Toyota Pickup 22re, auto, 3.73
cam.man67 is offline   Reply With Quote
Old 10-03-2010, 04:50 PM   #2
cdowns
cdowns's Avatar
Re: frame rust!
1/4 is pretty big// you can cut back to where the steel is solid and weld a patch in but make sure you make a template with referance marks before cutting //i normally used 3/16 or 1/8
Old 10-03-2010, 08:02 PM   #3
brn agn
brn agn's Avatar
Re: frame rust!
Occasionally board members will cut patch sections from donor frames and sell them in the classifieds section also. Here is an example:
http://67-72chevytrucks.com/vboard/s....php?p=4215615
1969 C10 SWB Project Charity Case AKA "Roscoe"
1971 Cheyenne Super A Combined Effort
The Service Station-A practical ministry for those in need
brn agn is offline   Reply With Quote
Old 10-07-2010, 09:12 PM   #4
Roland
Junior Member
Roland's Avatar
Re: frame rust!
Can you post a picture of exactly the piece you need?
Roland is offline   Reply With Quote
Old 10-08-2010, 07:21 AM   #5
cam.man67
cam.man67's Avatar
Re: frame rust!
Hope it's clear in the pics, the frame right about the right rear coil spring:
Old 10-08-2010, 09:25 AM   #6
marenick
Re: frame rust!
i had the same problem with my frame and i got the section of frame from bills truck shop.I just braced the frame with stock angle steel,cut out the bad and fit and welded in the new piece
marenick is offline   Reply With Quote
