Front drums stuck, need help
I just hit myself in the eye with my hammer trying to get the front drum off. So I give up and come here for help
![]() How does the front drum come off of my 69 GMC C15? I turned the adjuster spindle all the way in. I knocked the wheel studs into the drum, thinking they might have been holding it. There are 3 studs sticking out of the drum that look like the tips have been mashed in. I don't know if those have to come out or what is the deal.
1969 ![]() |
its all about the +6 inches
Re: Front drums stuck, need help
did you grind the rivits off the hubs? There's 3 if memory serves.
if memory serves, they had a screw on the face of the drum/spindle/axle. its been a long time and I could be wrong . anyway, hope this helps. cheers, Pat
You can try to remove the drum with the hub, then seperate them on the bench. It sometimes makes it easier.
A USED TRUCK IS A LOVED TRUCK! |
I was not sure if I should just break out the grinder and cut those off, or if I should take off the center nut and remove the whole thing...
1969 ![]() |
personally, I'd just pull the hub at the spindle. You'll need a new grease seal on each one... and some new wheel studs from the sounds of it.
If you just working on the brakes, remove the dust cap, cotter pin, hub nut and outer bearing to get the drum off, it all comes off as one unit. If you plan on replacing the drum then you have to grind the rivits off. Hope this helps. BTW, I too almost put my eye out on two seperate occasions trying to take brake springs off with a screwdriver ...I finally bought the right tools ...and bandaids!
![]() ![]() ![]() 69 C10 Stepside ~ Project 79 K10 Shortbed 4X4 ~ Sold 72 Chevelle SS Clone ~ Sold |
just remove the hub like they said// those riveted on brake drums are the originals from the factory try to keep them like that if at all possible as those drums are far superior to available replacements
#9 | |
Thanks for all the help guys!
1969 ![]() |
Some PB Blaster & a little heat goes a long way. Heat the drum evenly around the center. Often times it will pop right off.
1969 c-10 Step Side Long Bed. I-6 250cid = ![]() |
