Steering Question
I have a 69 K10 short bed step side. When ever I make a turn, the steering wheel is out of clock 90 degrees. If I make a r/turn & then go straight my steering wheel is out of clock 90 degrees to right. If I make a l/turn the same thing happens to the left. After I drive straight for a while it corrects itself. It is not the gear box because I just replaced it & there is no change. Anybody got any ideas?
1969 Chevy Long Fleet Custom C/10 (2nd owner) 1971 Chevy Short Fleet Custom C/10 (2nd owner) 2001 Chevy Silverado Ext Cab ![]() |
Re: Steering Question
Have you checked for play in the linkage? This means every single rod end. I would think a quarter turn worth of play has to be visible somewhere.
Ray |
Also check where the rag joint attaches to the steering box.
Check to make sure the box bolts are tight. Make sure the frame is not cracked around the box. Check the drag link ends for slop. Check to make sure the steering arm bolts are tight. Check the center link ends. Ummm......make sure the steering wheel is tight.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
#4 | |
