Closed Thread
Old 10-03-2010, 09:12 PM   #1
71rustpile
71rustpile's Avatar
Radio trim plate
Hi,
I've been looking for a nice single DIN radio trim plate for my 71 PU and 70 Blazer and couldn't find one so I had these made. It made sense to make more than two after all the programing was done so I had an extra 12 made. They are 6061 aluminum and are available in machined finish or polished and come with hardware. I have 12 available to ship immediately (Tuesday) and am willing to get more made quickly. Pricing will be $65 for machined finish and $80 for polished. Shipping should be around $5 but I still have to do some checking. Payment will be accepted by Paypal.
Dan
71rustpile is offline
Old 10-03-2010, 10:09 PM   #2
frednoah
86 Scottsdale
Re: Radio trim plate
Put me in line here. Would like outside dimensions to make sure it will cover the "hack" on my dash.
frednoah is offline
Old 10-03-2010, 10:16 PM   #3
huero
1969 Short, Fleet, and Beat
huero's Avatar
Would like to see picture of it installed. I would want one as well.
huero is offline
Old 10-03-2010, 11:31 PM   #4
71rustpile
71rustpile's Avatar
Outside dimensions are 8 7/8"x2 1/2"
Old 10-03-2010, 11:36 PM   #5
71rustpile
71rustpile's Avatar
Here are a couple of installed pics.....
Old 10-04-2010, 07:11 AM   #6
badboy007
badboy007's Avatar
I'll take a polished one.
badboy007 is offline
Old 10-04-2010, 05:50 PM   #7
alexr421
alexr421's Avatar
i will take a polished one as well..!
alexr421 is offline
Old 10-04-2010, 07:34 PM   #8
71rustpile
71rustpile's Avatar
Ok guys, looks like $5.00 should cover shipping via USPS 1st Class mail in the continental U.S. You can make payments using PayPal to precisecustoms@gmail.com. I am willing to combine shipping if you want to order more than 1. Make sure you include your shipping address in the notes when you make the PayPal payment.
Dan
Old 10-04-2010, 08:16 PM   #9
alexr421
alexr421's Avatar
payment sent..thanks..!
alexr421 is offline
Old 10-04-2010, 09:37 PM   #10
71rustpile
71rustpile's Avatar
Got it, will drop it in the mail tomorrow, thanks
Old 10-04-2010, 10:01 PM   #11
themeskin
hi will they come w hardware /inst also if the do put in line ill send ppl on thr thank u
themeskin is offline
Old 10-04-2010, 10:16 PM   #12
71rustpile
71rustpile's Avatar
It will include hardware and a scaled CAD drawing to cut out and use as a template for marking the hole locations.
Dan
Old 10-05-2010, 07:26 PM   #13
71rustpile
71rustpile's Avatar
machined vs. polished........
Old 10-05-2010, 08:55 PM   #14
DaSchlange
DaSchlange's Avatar
I'll take a polished one. I do believe I sent you a PM earlier. Let me know if you still have any left. Thanks!
DaSchlange is offline
Old 10-08-2010, 02:40 AM   #15
alexr421
alexr421's Avatar
got my trim plate today.. that was QUICK..! thank-you sir..!
alexr421 is offline
Old 10-08-2010, 12:44 PM   #16
HillClimber
HillClimber's Avatar
Somebody tried to cut out the left knob area of the radio on the truck I just bought and have been looking for a solution for it. This may be it.
HillClimber is offline
Old 10-11-2010, 02:50 PM   #17
frednoah
86 Scottsdale
I think the size should cover my hole. If the "ears" that the knobs poked through are gone, can I mount it?
If so I'd like a machined one.
frednoah is offline
Old 10-12-2010, 08:38 AM   #18
71rustpile
71rustpile's Avatar
I'm not sure I understand your question but the fasteners for my trim plate are 8 3/8" between. Hope that helps.
Dan
Old 10-12-2010, 01:24 PM   #19
DaSchlange
DaSchlange's Avatar
I was wondering about how it goes on... do you have to drill the holes and then screw it in from the back side?
Old 10-12-2010, 05:43 PM   #20
frednoah
86 Scottsdale
Dan
Hope the picture I borrowed helps. The areas in the red boxes have been sliced and I think folded back. They may be gone altogether. I haven't pulled the radio yet.
If they are gone, I'm assuming your plate won't work for me.
frednoah is offline
Old 10-12-2010, 06:11 PM   #21
DaSchlange
DaSchlange's Avatar
Ok dude, this is what this plate is made for. Go look at the pictures above where he shows his installed. This plate is for people that have had their dash cut for modern decks. Now, the question is, how badly bent is your dash hole? The only way we can tell you that it won't work is if we see a picture of it, and a fairly good one, lol.
Old 10-12-2010, 08:14 PM   #22
frednoah
86 Scottsdale
God forbid I ask a question before shelling out the cash to buy something. Just because it is made to put a modern deck in doesn't necessarily mean it will work on a dash that has already been hogged out. He could very well have been working from a virgin dash and left enough metal for his setup to work.
Sorry dude....
frednoah is offline
Old 10-12-2010, 08:27 PM   #23
DaSchlange
DaSchlange's Avatar
Well no it was an honest question, I wasn't dissing you. How bad is your dash? Is there any metal left that you can bend back so that the trim plate has a backbone to attach to or is it worse? I can't give you my opinion unless I see your dash first hand. Whenever 71rustpile logs on he can give you the dimensions such as the width between the two screw holes so that you can measure and see if you have enough slack...
Old 10-12-2010, 08:42 PM   #24
71rustpile
71rustpile's Avatar
Just to clarify, the trim plate will cover the entire flat section of the recess for the radio. The dimensions of the trim plate are 8 7/8" x 2 1/2", so if your dash is hacked beyond those dimension this probably wont work for you. The distance between the fastening points is 8 3/8". If you don't have any dash metal wider than that dimension you may have to weld metal back in to your dash for something to drill and fasten to.
Dan
Old 10-12-2010, 09:39 PM   #25
DaSchlange
DaSchlange's Avatar
Hey, Dan, I know I PMed you about a week ago about getting one, but my extra cash ran out since I had to replace the distributor and coil in my truck. Do you still have a polished one left?
Closed Thread
