10-03-2010, 09:16 PM | #1 |
Auto trans mounted shift linkage needed
I need part of the shift linkage on an automatic equipped truck. I bought a truck with no motor or trans. I still have the rod that runs from the column to the frame, the frame bracket and the frame mounted linkage.
I need the piece that bolts to the transmission its self that fits the piece that comes from the frame. I also need the trunion (?) that bolts to the column that tightens down on the rod for adjustment. Sorry if my description is not too clear. I have never known the technical terms for these particular pieces. Last edited by WIDESIDE72; 10-03-2010 at 09:16 PM. |
10-03-2010, 09:40 PM | #2 |
Re: Auto trans mounted shift linkage needed
Ive got one for you... it is for a TH400 though.... dont know if they are different if you have a TH350....
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
10-03-2010, 10:37 PM | #3 | |
Does anyone else know, or have input as to what they used in swapping in an O.D.? There are several threads on here regarding swapping them in, but no details as to the linkage, so I assume that the old TH 350/ 400 linkage works on the 700 (?) Could you post a few photos? |
10-07-2010, 11:43 PM | #4 |
Does anyone have a photo of this part?
10-08-2010, 03:47 PM | #5 |
