Old 10-03-2010, 10:49 PM   #1
dccarpenter
Spacing out my wheels
I have an '84 Chevy C30, it was originally a utility body , it has been fit with an '04 dually bed after the utility body rusted out. The axle is apparently shorter than the axle of the '04 dually's was, the previous owner just cut the wheel wells on the bed down the middle and added a 4" strip of metal in between to space them in a bit.
The problem being this leaves me with 44" inches between my wheel wells at the center of the bed, I'm a carpenter and often need to put 48" + plywood in my bed, with a cross bed toolbox sitting the ply over the wheel wells is a nuisance. Is there a spacer available to push my wheels off the hub a bit so I can cut out the welds and return my bed to original dimensions?
dccarpenter is offline   Reply With Quote
Old 10-03-2010, 11:17 PM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: Spacing out my wheels
your 84 could be a cab and chassis they have narrower rear ends then a fleet side dually, causing the wheels to stick in further
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 10-04-2010, 06:31 PM   #3
dccarpenter
Maybe so, the bed had been replaced before I got my hands on it. I'll just google up some spacers and see if I can come up with something...I really want to re-work the way I have my bed configured with the different toolboxes and being able to lay plywood flat instead of having to leave room with the toolbox setups for it to sit in angled will really help.
